biminiLX
I don't care what's been said.I think its been said many times..3L cams belong w/3L uim..same for the svt cam's.
No dyno back-to-back tests from what I've read.
I know engines and cams with the same lift but more duration and overlap (which if what I remember reading is what the SVT cams have compared to 3L cams) will make push peak tq and hp higher in the rpm range and produce more at higher rpms.
It depends on the engine and rpm range we're talking about, and the 3L cams may in fact make more average power, but what I stated should be proved on a dyno.
Also, look at the application for the cams---Ford engineers will tune for most average power for the intended application. SVT has a higher rev/MTX vs. lower rpm/auto. Think about it, my opinion:shrug: .
-J
