Grenade
What are better, 2004 3.0 Taurus cams, or '00 2.5 SVT cams?
What do you mean not as fun? What's the differance?I vote for 3L cams, if I have to do another 3L swap I'm keeping the 3L cams, I just dont find my current SVT as much fun to drive as my last one with 3L cams and I would put money on the fact that my last 3L with 3L cams would beat my current 3L with SVT cams and both have the same mods!
Aaron
I had heard that the 2004 3.0 Taurus cams were a bit better than the '00-'03 cams. So I thought that maybe they were closer to the 2.5 SVT cams. I am currently driving the 3.0 with the hybred conversion. I'm pleased with the power, and I'm sure it will run even better when I get it tuned on the dyno in the next month or so.
Thanks, I'm still learning. I couldn't remember the pros and cons of each.Shawn,
You have a ported 3L not a hybrid 3L. A hybrid 3L uses 2.5L heads and a 3L block. You have a 3L block and 3L heads ported out for 2.5L intakes.
Chris
The SVT cams I have to really get high in the revs, the 3L cams I had plenty of low end and the top end still felt strong. With the 3L cams I never had to down shift I would just hit the gas and go, I dont feel that same power on tap with the SVT cams. While cruising if I just tapped the gas I would get thrown back in my seat once again I dont really feel it with the SVT cams. Kinda hard to explain I just find the 3L cams had alot more of a fun factor when it came to driving and the car still pulled very hard to speeds I will not post. I just find the 3L cams were better for all around driving. 1Fastdad can vouche for what my current and previous SVTs are like. The 3L cams made the alot of tq and talk about tq steer geez, the SVT cams still give me tq steer but not so much down low. With my 3L cams I had tq steer very low in the RPMs I find that with my SVT Cams I dont get tq steer until about 3,300ish RPMs. FYI as stated both my 3L's had the same mods and the same tuner the only difference were the cams and both cars were tested 8weeks apart. Basically the same tune was used just made the change for the cams. I hope this helps and makes some sense, if not just let me know.
Aaron
Aaron
re SVT cams: 3300(ish) RPMs isn't low?...snip...
...snip...
Compared to having tq steer at lower RPM no 3,300 isn't low .
Rara thanks for clarifying my point better and peraking of ST220 UIMs .
Aaron
I have torque steering in the low rpms with my svt cams :shrug:
