striker2
Official CEG Vendor
forget the drain plug on the radiator. grab the pliers and crawl under the car. on the passenger side there is a hose that goes under the oil pan near the subframe. it is actually bolted to the pan. this is part of the lower radiator hose and leads back to the heater core. undo the clamp and pull of the hose. let he coolant drain from there.Ugg... Looks like my engine will be getting a nice coat of coolant over it then :crazy:
Unless, is there some "special tool" to take out the plug? The only thing I can get to it with is my drill with a flexible attachment thing...
it is the easiest place to drain the coolant from and it also happens to be the lowest point in the cooling system.
