You might be a CEG'er if....
- you might be a CEG'er if u hear someone talking about "crows feet" and u chime in about your car and everyone is like wtf?
- if you can tell the stumped dealership mechanic what is wrong & the most efficient way to fix your car
- and still end up having to take it home & fix it yourself.
- if you feel uncomfortable in ANY other car because there are no warning lights on...
thats so depressingly true on multiple occasions.
with my pre98 I had so many issues with misfiring, I took it to two different mechanics because I was stumped. I had replaced the ignition coil, wires, and plugs. I told them the only thing I think might be an issue would be the coil because it was an el-cheap-o one. I just didn't know how to test it, they said it wasnt possible, both shops did.
I ended up buying an upgraded Accel ignition coil and installing it, never had another misfire.
Jackasses.
1. You can't fill up with gas without opening your trunk.
2. When thirsty, you drive around trying to find a place that still sells 12 oz. cans that actually fit in you're cupholder.
3. You take the offramps at excessive speeds hoping that some idiot in a Pontiac will follow you trying to do the same.
4. After blowing up an engine or two, you learn to take only the left hand offramps at excessive speeds.
5. You can't help but snicker whenever someone mentions that his/her SUV is "fun to drive".
6. You would consider paying 30K for a new Jag BECAUSE of its Mondeo/Contour heritage.
Holy ****!
Those were all my contributions! From five years ago? Seems like it was yesterday.
if a mechanic tries to charge you 3 hours of labor to diagnose the moose and still cant come up with an answer. you then go to the home depot and buy a 5 cent piece of copper and fix it in a matter of minutes
-you buy a contour then sell it. and then get another contour down the road.:blackeye:
- you know who rawburt is and that he is a Q-Tip with a pulse
- you feel like something's wrong because you DO NOT have a CEL
- you know EGL is the ****, or full of it.
- you can tell the difference between a trans problem or a stage 3 clutch
- you've said " i'm in" on a group buy only to back out because " you don't have the money "
- you've had hetfield's moob squash your glasses
- You know todras and his ridiculous post count
- if you've ever heard "why is there a forum for contours? and why are you on it?"
- you have insulted steeda's mom
-You buy parts you don't need, strictly because they may not be available in as little as two weeks.
-You can sing Bill Jenkins' "hold" Muzak from memory.
-Your car's alignment is good... until you hit a bump.
-You've received an "official" document (ticket, work order, etc) that's called your car an Escort, Taurus, or Neon.
-You've bought one or more sideskirts to pillage them for jack point covers.
