Well, its coming Directly from the engine and to me it sounds as if someone droped a bolt in the engine and its rattaling around. When I droped it off at a shop the mecanic called me back and said he stared it and imedietly shut it off. "It sounds like its getting worse, as if its self destructing." They towed it to a different shop and they told me that it was the rod bearing.
well guys update, i took the car to fords for them to hear it, the stupid mechanic said "piston slap" the engine needs replacing, his boss was out there and i think they either 1 wanted to get rid of me or 2 they couldnt be bothered to know about my issue with the car, now the car started to make the rattling noise even on idle, got to work and it turned off on me at the junction near my work, i tried to turn it on and it was making a really bad noise like a clacking noise and died again, i knew there and then connecting rod bearing, so i pushed the car by myself up a little steep to the car park at work, (god damb my car weighs a ton) had to stop at the entrance to work as my wrist was hurting, no ****er helping me push either, managed to get it into the car park and called the recovery company im with to come pick me up and tow me home
he came after work right on time like they said, he said ill try to fix it here and then and i said its not gonna be fixable here as i know its the connecting rod bearing thats turning in the engine causing the horrible clatter in there, he turned it on for a couple of seconds, turned it off and said "this aint goin anywhere" so he got my car onto the wheel lifts which im lucky as my body kit and the lowered car is really low to the ground and he towed me home slowely,
guys heres where i need the help/advice, i wanna replace the bearing on that first cylinder as it was comming from cylinder 1 which as u know is on the passanger side on the contour, or on yur left hand side if yur standing in front of yur car looking towards the engine, well if i replace the bearing, will the noise stop? Or do u think the crankshaft is damaged and wont make a difference, ive got 12 very good bearings from an engine that im doin over right now but ive brought new bearings for that one so id use the other used but good condition bearings on this one to see if it will do the job, as said do u think it will solve the problem, in theory it should do as its the bearing thats come off its seat on the cap and is clattering in there, but will this be enough to damage the crankshaft u think?
also how hard is it to remove the oil pan, am i right saying u need to drain the oil first, then remove the "Y" pipe and then remove the 15 bolts holding the sump, then undo the baffles and pick up tube and then turning the crankshaft until i can see the first cap which will be near the passanger side of the car and then replace the bearing with one of mine and make sure its on there straight and take the damaged bearing off from the cap off the first one, then replace procedures and then refill with oil and see if the noise is gone?
I need this car working as its my drive to work which is 20 miles away and its gonna get to the winter seasons so really want my car back on the road and the other engine im still waiting for the bits to come in to complete it,
any info appreciated guys thanks sorry for the long post :blackeye:
