98SVTC
Additives won't automatically adjust your lifters (if that's the problem) just like they won't fix any other problem. Check to see if the lifters need adjusting first and as some other posters have said, additives don't do anything anyway except lighten your wallet.I will use the Motorcraft 5W30 Synthetic Blend, Motorcraft FL-2005 Oil Filter, and additive....
...which additive would be the best to use?
STP Blue, STP Red, or Lucas - but there are several type.
Then when I can afford it, I will have the valve clearance checked.
Karl
