warmonger
i believe my .99 cent champion plugs finally $hit the bed after 6 months, or atleast im hoping its that, but i dont get why my cat would be glowing, its not blocked or anything..
Assuming the cat didn't break and its not plugged......(which can happen on even new cats):
Then it usually happens with too much oxygen or air in the exhaust, as in an injector stopped working and one cylinder was just pumping fresh air into the exhaust.
If you had a spark failuer then there would be raw fuel in the exhaust and that usually cools the catalyst down.
However if it was at cruise mode and the fuel was injected it could make it hotter if the fuel was in small amounts.
First thing I'd do is drop the catback and then start the car and see how it runs. If it is still misfiring then you know its the engine. If it runs good then it was probably a broken catalyst and caused the exhaust to backup.
Also with the cat that hot you may want to look into the end with a flashlight and take a peak at it.
