In my opinion, if you don't know the history of your water pump, consider it a maintenance item and replace it. $70 and an hour of your time is cheap insurance.
from what I have found the switch over was in late 99 ... so a 98 would have the black impellar ....
My '99 Mystique was built in December 1998, and I'm assuming by then Ford had changed to the white impellar, since I've run over 231,500 miles on the original water pump. However, I have a self imposed "red line" of 3,000 RPM on my engine, so I've subjected the impellar to much less stress than most people. When I asked my mechanic about replacing it years ago, he said he had seen only one 2.5 L Duratec engine with a failed water pump, so he advised againt messing with it.
.... When I asked my mechanic about replacing it years ago, he said he had seen only one 2.5 L Duratec engine with a failed water pump, so he advised againt messing with it.
Ahh.. so.. he's worked on one Contour, then... cool!
