genesis14
Leds don't die from someone touching the bulb. Your thinnking of a filament type bulb (like a headlight bulb) Leds are a semiconductor diode that emits incoherent narrow-spectrum light when electrically biased in the forward direction of the positive-negative junction. This effect is a form of electroluminescence.(thanks wikipedia)
They are HIGHLY voltage sesitive. If you are unsure of how many volts it takes to light an led, FIND OUT. If you don't find out, even 1 volt over the recommended voltage will burn out the led. Sure it will look bright, but for only a second or two (or worst case ... not at all) for a 12 volt system you should use a 470 ohm (or higher) resistor. for a 15 volt system (because or cars can get up to 14.8) you should be using a 680 ohm resistor. this is based on an led with ratings of 3.2 volts and 20 ma of current on a 15 volt system
simply led calculator http://led.linear1.org/1led.wiz
I buy my leds from www.besthongkong.com because they give me specs right on the site.
