Ok im not really trying to knock your product, but if it's already returnless theres no point in buying your product. Cause you dont have to fab the fuel rtail and its almost basically a straight drop in for the 3L besides the modes you have to do to the outside ect. I dont see what the point is putting a svt intake on a oval port motor. Im mean unless you got some dyno numbers showing a 3L with a svt intake and then the same 3L with just the 3L intake, and making better number with a svt on a 3L. 3L cams on a split ports are not effective and dont make enough power, and splitport cams in a 3L oval port setup also makes less power and is pointless. if you are using oval port heads then SVT
cams are a serious no-no. Remember that the port timing is different between both lobes of the intake ports and that may attribute to losing power - Not gaining it. For the most part, almost everyone thought using SVT
cams in a straight 3L was a good idea until they did their homework and found out that the
cams were tuned for split ports - Not oval ports.The flows,pulses etc etc are no where near the same.I think the 'ego' of the 'SVT' sticker is still around! And it its
blatantly obvious the SVT UIM has way less volume than the 3L intake. Look at the size of the runners. Then as soon as the air comes through teh throttlebody hits a wall goes around the corner hits another wall ect. THe SVT UIM is a poor design. It might have a little better velocity than a 3L upper but I Wouldnt know cause I never done a test but you dont have to do a test to see that it has more volume. Another thing I got a full 3L swap in my 98svt with out having to fab a fuel rail. Just some minor adjustment to some fuel lines And for people wanting to do a 3L hybrid you dont have to use jb weld or any other kind of filler."Just tap the hole with a 3/8"x16 tap and installing a 3/8" Set screw coated in liquid teflon. It works out pretty good and only takes a minute or two to install.With the rear tensioner off, I use a little lithium grease - Coat the hole and then tap. It catches most of the material, and what it doesn't I use brake parts cleaner to flush down the feed hole which exits at the tensioner feed hole. Comes out clean every time." Thats a quote from the owner of FCO. Just thought I would share
