He should have bought mine!!!!!!!!
because im sure he knew that his diff was going to explode a couple of weeks in advance.
Age difference here. My friends, high teens to mid to low twenties. Yours, 30's give or take. Now, if one of my younger buddies with limited money wanted to buy an SVT because it was a cool looking race car. Do you still think that is complete BS... i dont.
I'm just saying, an SVT isn't the best car to get if you have limited cash flow and are looking for something performance wisse to have fun with.
This transmission style is easiest to install a replacement diff. The shims are located under the races, so either replace the bearings and races yourself or have a shop do it - new bearings + old races is lame and is totally cutting corners. Once you have a transmission without cv's in it, all you have to do is pull the bellhousing and the diff sits on top and pulls directly out. A Torsen is greatly advised - this job should only be done once! Get the upgraded shift forks as well, they are reasonably cheap and make a HUGE difference. Forks can be pulled and replaced in under 5 minutes - CSVT#49 has a guide on this. Good luck! Your on your way to building a bulletproof transmission.
I believe I already stated the point.
For the EMO's in the crowd I'll state it again
Oh, I had a pro trans shop install my Torsen because I dont have a bearing press and there is no reason what so ever to replace shims. Shims behind the race see no wear - if you buy your bearings and races from Ford as well as a Torsen from Ford there is no measurement required. Ford casts their products with exact specifications and as long as you use the same shims there is no worry. I have done quite a few ring and pinions using Ford parts and measured the backlash before and after instalation and it was spot on to the .001.
I still say replacing bearings and leaving old races in there is a shortcut.
I hear you on the castings being close to exact specifications, you can press the bearings on the diff up and down by as much as a 2-3 milimeters. So if you just shove the bearings on the diff to where they look flush with the diff housing and try to use your old shims under the new bearing races it's going to be too tight and you will experience premature diff bearing failure. The chances of you being able use the exact same shims that come out would really be really low, it would depend on how exact the new bearings were pressed on compared to the old diff for you to be sure you can use the old shims. The way I see it is the shims are there to compensate for variations in the bearing depth on the diff. So somebody at Ford already pressed on bearings on the stock diff and adjusted the bearing races accordingly for that particular tranny and I just matched that. I did it the other way around I matched the diff and bearings to the case vs the case to the diff and bearings. So if I took a shortcut it was that I used a bearing race with a bit of mileage on it, kinda like reusing rod bearings after you pull apart a bottom end, but if they truly show no wear it can be done. Not ghetto fabbing, just using what is still good and saves time/hassle. I still took time to verify that the diff is within the factory spec inside the case which is the most important part.
So if anyone wants to use this method, use it at your discretion.
