warmonger
Ok, speaking of problems. I had to take the valve covers off today due to a minor oil leak on the rear cover and I decided to torque down the cam caps to spec since the engine had already been running fine and oil had a chance to get in there. When I tried to start it back up the engine was running very rough and stalled out. WTF is going on with the cams? I'm guessing one of them is binded and I'm about to take it all apart and put the 2.5L cam caps on there. If I do this, do I need to pull the timing chain off this engine and completely redo all the timing to ensure that the cams work fine? I have another car so right now I'm more concerned about getting this running the way it should. Thanks in advance for your help.
Well you SHOULD have done this right in the beginning before you started it.
With that said, I'd swap out the cam caps with the 2.5L ones right now in the hopes that I can fix any issues first before yanking everything back out. Just swap them out one at a time and you can leave the chains installed.
The right way is to figure out exactly what went wrong and fix it.....but you're already committed so it doesn't hurt to try something else before doing it all over again.
Most of you don't know it but the 2.5L cams and 3L cams have a different sized thrust surface.
The 3L cams have a larger thrust surface on them than the 2.5L ones so you would be better off using the 2.5L thrust caps with the 2.5L cams anyway. It's normally not an issue because the 2.5L thrust being smaller fits easily in the 3L thrust caps.
