madmerc00
how would i clean the fuel system. it has junk at the bottom of the tank and when it gets to 1/4 of a tank it starts to miss and stall. Do these cars need injectors every so miles or something. please give me ideas!:help:
so i will have to get the pats system out of that car also?
Post the exact code....I know there is alot of junk at the bottom of the tank and getting to the injectors. i have already got a CEL code from it. ...
well i am going to put the upper and lower intakes on and everything else so i was justing going to switch the pcm.
isnt the svt pcm programed for svt cams as well?
it most likely is but there have been some, myself included that have run without the SVT cams and just the pcm ... car runs great ... either way the pcm should be able to adjust timing to run correctly .... the one thing you need to address is if you swap to the SVT injectors, then you definately need a tune or the SVT PCM for the car to no throw a lean code on both banks ...
you know thinking about it more all cams do is control how long the valve are open, therefor it controls how much air is moved throught the engine ... the computer controls the timing and it knows how much air it is taking in and how it is leaving so it should be able to adjust without an issue ...
