What fixed the light?
I did notice that without the 12V line that energizes the stator (the little single connector), the battery light doesn't come on
Was studying for promotion and noticed I gave some misinformation. Don't want to mislead people, so want to correct this...
The +12VDC single connector energizes the rotor on an AC alternator. The rotor is the electromagnet, the stator coils are the conductor. With motion (and 12V on the rotor), the magnetic lines of force "cut" through the conductors, creating electricity.
Reason the magnets are not stationary and the conductors are turned to "cut" through the magnetic field (as they are with a generator), is because the high voltage/current doesn't have to pass through brushes, making them more reliable.
The alternator actually puts out AC voltage internally. There are a set of diodes (rectifier) that turn the AC into DC.
I'm not 100% on how the voltage regulator works... it could be a potential transformer (AC, so before the diodes) or a DC-DC convertor. :shrug:
Anyway, just some gee-whiz info for y'all.
Here's a pic of it... the top is a "generator" while the bottom is an "alternator." Notice how in the generator, the conductors are moved through the magnetic field, where as the alternator the magnetic field is moved through the conductors?
