BillyT
Is this normal or should I take it back right away and demand they fix it so it's silent?
ROTFL. This "beating around the bush" thing is BS. Let us just go for the jugular immediately. :laugh:....You should insist on an alternator that is silent like the OEM alternator, like every other properly functioning alternator on the planet.
what you didn't say is if the alternator was a rebuild, I have to guess it is and I bet the bearing where not changed when it was rebuilt. You are much better of getting a junk yard Motorcraft alternator over a rebuild but ultimately if you don't want to have any issues in the long run get a new OEM Motorcraft alternator ...
this is just another prof that the contour like OEM parts over aftermarket ones ...
Are you sure it's the alternator and not a new belt that is making the noise? I replaced the serpentine belt on mine last year and I noticed a slight whistle for about a month.
