LLADNAR - What shape are you going to make your ports when you start that?
i was going to make them match the lower intake gaskets,, as much as possible anyways,, the main thing is getting the injector enough room to work
Erm, okay - what things? I can't find the info anywhere (and not for lack of searching on all of the various incarnations of this board plus other boards plus intarweb in general).It works, you just need to alter a couple things.
I'm not exactly a newbie to car stuff (this is my 7th motor swap, last one was LS1 in my 240Z). But I generally go for path of least resistance. So, I have an idea of the effort to swap timing covers, and right now, it's looking like maybe less effort than the head-scratching plus mod'ing of the Escape cover. I can see that the thin cross piece has to be cut-off. But the belt routing looks like a project (plus getting the correct size of the belt req'd). For one thing, the AC compressor is still in the car, so figuring out the exact belt layout is an after it's a done deal kind of thing...
Where is PS on the Escape anyway?
Well, no, PS is definitely NOT in the same position. On the SVT, PS is between the heads. This 05 Escape motor has a big fat honkin motor mount bracket there.I see, I guess the 05 cover is different the prior ones (like nima posted) work, you just use an escape belt. All the accessories are in the same position as the contour, the idler is the only difference
I guess I'll just use my SVT cover. This project grows...
