Flame me if you must ,But I have gone back to my stock factory premium sound amp .Earlier this year I had a problem with my left front door speaker not working on occasion.The only way I could get it to work was to fade and balance all the way to the left front and CRANK it .It would work for a while then shut of again ,well long story short I thought that the amp was the problem because that is the general opinion around here so I bypassed it :nonono: Come to find out one of the short jumper wires I made to splice the factory harness to the aftermarket speakers Lightning Audio B3.68.3 had some corrosion causing a high ohm load which would shut down the channel
The way I found this is by waiting for it to stop working, taking the door panel off and hooking up a known good speaker directly to the factory harness and waiting for it to cut out .when it didn't I tested the short jumpers I made with an OHM meter ,problem fixed
For more flaming fuel I will add that I have a DUAL XR4110 mechless head unit mostly because I was tired of CD's skipping over every little bump in the road and the price was right . This unit is advertised as 60 watts but is 5watts x4 RMS .So not being a super high output unit once I got the door speaker figured out I hooked the stock amp back up thinking that if the factory door speakers say 20 watts the factory amp shouldn't be less than 5 watts rms:shrug: .It sounds better,has more power and is easier to tune it to my (ducks flame thrower)Dual Xia 2 460 amp powering a Dual Xinmbp212 sub box .
Now I will not claim this is SoundQ SVT level or even close for that matter but for what I have invested I and everyone that has heard it thinks it sounds very good
I did learn some stuff along the way .
1 you need a 5 volt voltage regulator to power the factory amp
and 2 speaker wiring
Location~~~~~~ aftermarket ~~~~~~~~~~~~~~~~~ stock ford ~~~~~~~~~~~~~~ w/amp
left front+ ~~~~ white ~~~~~~~~~~~~~~ white/black ~~~~~~~~~~~~~~~~~~ green
left front- ~~~~ white/black ~~~~~~~~~~~~~~ brown/yellow ~~~~~~~~~~~~~ white/orange
right front+~~~~~ gray~~~~~~~~~~~~ white/red ~~~~~~~~~~~~~ white/red
right front- ~~~~~ gray/black ~~~~~~~~~~~~~ brown/red ~~~~~~~~~~~~~~~ brown
left rear+ ~~~~~ green ~~~~~~~~~~~~ white/purple ~~~~~~~~~~~~ light blue/black
left rear- ~~~~~ green/black~~~~~~~~~~~~ brown/white ~~~~~~~~~~~~~ yellow
right rear+ ~~~~~~ violet ~~~~~~~~~~~~~ white~~~~~~~~~~~ purple/white
right rear- ~~~~~~~ violet/black ~~~~~~~~~~~~ brown ~~~~~~~~~~~ light blue
FLAME ON JOHNY
FLAME ON JOHNY
