E
Eaglez1 Offline OP
E
Today I looked at how bad the hazing was and all, since I plan on cleaning them this weekend but what im wondering is in 1 headlight it has condensation in it. I don't want to take the headlight out so is there any other way I could get the condensation out?
F
F
Remove you high beam bulb during some nice dry, hot days. That should clear up and, not so bad moisture problems.
E
Eaglez1 Offline OP
E
Anyway to do that and not take out the headlight?
If so how?
H
H
If so how?
You got a pre or psot 98? Pre 98 the bulb just twist out, open the hood, the thing is black, twist it and it pops out. Also condesation means you most likely have a crack, I did and had to replace one of mine. Ebay if your friend though as they cheap off of there.
E
Eaglez1 Offline OP
E
Post 98
F
F
then there is 3 screws holding the HL in, plus the two holding the grill on. remove the grill and then the 3 screws that secure the HL.
R_G Offline
You will locate the 2 top HL screws easily, however pay attention to the 3rd one - it's sitting in the middle but lower, kinda deeper.
what I found that worked was to take out your headlight and pour a little alcohol into the the headlight(through the hole where the bulb goes in. I used a swab to smooth the alcohol around then I poured it out...put it under a heatlamp and let it sit overnight. Problem solved.
~darp~
Originally posted by PÃ?â?¢WDÃ?â?°Ã?®CÃ?Ë?Ã?Æ?TMÃ?â?¬N:
I can do anything if i can find that powder .
E
Eaglez1 Offline OP
E
2 more questions...
1)Is it easy to take them out?
2)How easy is it to put them back in, and how do i do that?
Here are pics are these the 3 screws im looking for?
H
H
Holy crap from what I see that looks like shittest headlights ever on CEG.
