Page 2 of 2 1 2
Originally posted by zgendron:
You may want to get it checked out. I don't know enough about Auto Trannys to provide any info. I do know that most problems with them get more expensive the longer you wait.
Does it slam(shift) into gear when you hit the brakes hard too?
That's the weird thing..it doesnt slam(shift) into gear ...it just shuts off...
___________________________ '95 Contour GL 2.0L (170K) A/T
Check the BOO (Brake On-Off) switch (brake light switch). When you hit the brake the TCC is disengaged. If the switch is bad or out of position this canā??t happen and the engine will stall under hard breaking. If it stalls every time you put it in gear then you have real TC problems. During normal breaking the TC will unlock during the down shift to first.
jeff
have you fixed your ford lately?
jeff
Hey...thanks for that advice...i'll definitely try it and certainly hope is the problem...just a little question...
where's is such switch located and is it changeable?
thanks one more time...i strongly appreciate any help
Page 2 of 2 1 2
