50mph ... red traffic light...wasnt paying attention...hit quick the brakes....automatic transmission downshift to first gear...car dies... Turn switch off and back on and car starts again and i keep on moving...
Its been doing this lately but only when suddenly i have brake and as soon as it stops it shuts off.
Any ideas?
thanks in advance,
'95 Contour GL 4 Cyl. A/T 170K miles.
___________________________ '95 Contour GL 2.0L (170K) A/T
Z
Z
The only thing I could think of is that something with your Torque Converter isn't working. It is then causing the car to stall as it comes to a stop.
- Zack WANTED: T-Red HEATED Side Mirrors FOR SALE: 4 14" Alum Alloys and Nearly New Avid H4s Tires w/ Center Caps 2000 T-Red SVT 1995 LX V6 MTX (RIP)
Torque Converter?
well if that's the case...any solution
If thats the case, then you may have to replace it. or it could be as simple as a sensor...but id put money on replaceing the TQ Conveter.
Lupe
where's that located at? and how much does it cost... easy to do by a do-it-yourselfer ??
You have to remove the tranny to get to the torque converter....Not a DIY task IMO....If you have experience and your confident, they yes you can DIY...it all depends on your ability....
But, because you asked where it is, im guessing you have had no experince with it.
From what peple tell me its about 2000$ to get it done professionaly...im not too sure if that includes labor or not.
But its definatly not a task to be taken lightly...I reconmend, you go to a shop to get your problem diagnosed first...go to a shop you trust, try not to go to the dealer unless you have to, unless you have had good experinces there.
Lupe
Holy [censored]...!!! i think its time to either run my car till it can't no more or sell it right away and move on to something else...cuz I am DEFINITELY not spending 2G, not even 1G in fixing that... no way!!
Check out the Transmission forum....some of the guys there may have a fix....that is cheaper than doing it yourself....Also, get it looked at!!!! have it diagnosed...it may be simpler than that.
Good Luck!!!
Lupe
check out the forum but nothing...
i wonder how much longer can I run it till the car scream and say: That's it !!! today was the last day???
Z
Z
You may want to get it checked out. I don't know enough about Auto Trannys to provide any info. I do know that most problems with them get more expensive the longer you wait.
Does it slam(shift) into gear when you hit the brakes hard too?
