#996170 07/04/04 10:37 PM
Here's the deal,
Temps are about 15c-18c, nothing done different with car, and now since a week ago the car stalls after sitting for 8hrs or more. Problem is that it stalls on the first attempt (starts but quickly idles down and stalls) but continues to run on the second starting attempt.
Any ideas CEG?
Thanks for any and all your help,
Stephen
96 Contour, GL, Zetec, ATX. 03/18/1996 Build Date. Drop in K&N NGK Laser Platinum Premium Spark plugs Niehoff Premium Ignition wires Wheel Well Air Intake Resonator removed. *Just the beginning* 2000 Windstar SEL K&N Air filter
#996171 07/04/04 10:48 PM
sounds like it maybe related to the EGR valve stuff????
to see if the egr valve is working you remove the plug to the IAC idle control selenoid... then put vacuum to the
vacuum port on the EGR and pull a vacuum on the EGR... if it kills then the EGR is working.... thats what i remember.. so it could be the IAC ??????
give it a try....
#996172 07/05/04 06:36 AM
Is it stalling when in gear or in park?
#996173 07/05/04 10:14 PM
It is stalling when in park, 10 seconds after first attempt to start.
I'm stumped on this one!
