Originally posted by MeanGreen2: Originally posted by Dandan27: Originally posted by Rogerm60: A bad fan will cause that, is yours coming on?
Yes it does come on, but it's up around the "L" when it does.
If your thermostat hasn't been changed before, and there are no obvious coolant leaks, my guess is that your thermostat is getting lazy...be good insurance, anyway. And while you're at it, change the PCV valve [between x-man and block, held in w/ 1 bolt that is located just above trans/just below outlet housing]...it'll be real easy to replace, once you remove the housing.
Thanks for saying where the PCV valve went I couldn't figure out where it went( I looked everywhere under the hood) and I didn't want to take it to a garage and have them find it (I'm quite stubburn). I'm also having the same temperature problem with my car.
Aaron
AKA NVS SVT
98.5 Silver/Blue SVT#4553
Yeah it's modded
98 T-Red/Blue SVT Contour Totaled 06/05/06
03 3L,VCN 2000,CAT Cams,MSDS Headers w/Y-Pipe,XCal2 and lots more
