Posts: 124 |
Which one of these cat back systems should I get? I'm interested in the best performance regardless of price. The Bassani exhaust I think looks the best, but I'm sure I could get similar tips for the Borla exhaust...now just which one's the best? I need some experienced advice here...thanks  Jonah T-Red SVT '00 No performance mods to date...except a K&N. Will be getting a KKM soon.
Big gulps huh? Welp, see ya later
Posts: 916 |
Bassani, had it on my SE... very nice but, $500 bucks is alot for 7 hp.... anyways i put on my stock SE exhaust, cut off the muffler, went to the track, ran .5 quicker and gained 3 mph... go figure, all i did was take off the exhaust...
1999 T-Red Contour SE Sport
Posts: 71 |
I'm biased because I own a Bassani...
I read a older string that stated the Bassani with the tip resonators removed had a 1-2 HP gain over the Borla. All of this is also based on your intake. With my KKM and Bassani I have noticed a small increase in performance (.5 seconds) in acceleration but I have also noticed engine braking has suffered.
The Bassani without the resonators is quite a bit louder than the Borla but I really like it...
Jason L Brougham jbrougham@yahoo.com 2000 SVT Tropic Green # 899/2150 Build Date 12/13/99 KKM True-Rev Bassani Quiet Thunder Cat-Back B&M Edge Shifter OBX Billet Pedals http://photos.yahoo.com/jbrougham----------------------
Posts: 1,732 |
use the search: http://contour.org/cgi/ultimatebb.cgi?ubb=search&search_forum=6 for "bassani" "borla". i'm also debating between the 2, but concerned about droning issues. waiting to meet up with antonio who has bassani to check out the sound. good luck!
- Pete - 00 SVT SF/MB - 1522/2150 - DOB 1/12/00 ------------------------------ 92% says your group-NOT HOT 85% says your either wrong or BLIND Blackhawk Down did NOT suck you know who you are.....
Posts: 124 |
Thanks guys...sounds to me like the Bassani might be the way to go...but I'd like to hear it myself too...I don't want it to be too loud.
Posts: 1,732 |
i'm going to check antonio's out on thursday night. i'll let you know (IMO) how much louder the bassani is, and if i think it's too loud.
Posts: 1,812 |
everything I've read on this topic states the bassani w/o resonators will get you 1-2 more hp than the borla. never hear bassani, but I hear it's kinda loud w/o the resonators. I went custom...i have one muffler in the middle, 2.5" piping, two strait pipes after the split, and that's it. Kinda like 99redse, but I have an svt (1 pipe vs. 2 pipes). It's honestly not too loud, and it sounds very badass. Might be cheaper (depending on materials), and could even produce more hp (1 muffler vs 2 in bassani).
2000 Silver SVT #1602 Check it out in the registry! Mi Coche
Posts: 2,906 |
Originally posted by Derk2000: everything I've read on this topic states the bassani w/o resonators will get you 1-2 more hp than the borla. never hear bassani, but I hear it's kinda loud w/o the resonators. I went custom...i have one muffler in the middle, 2.5" piping, two strait pipes after the split, and that's it. Kinda like 99redse, but I have an svt (1 pipe vs. 2 pipes). It's honestly not too loud, and it sounds very badass. Might be cheaper (depending on materials), and could even produce more hp (1 muffler vs 2 in bassani). what did you use as a muffler? I want to do this exact same thing but was concerned about the sound. I "want" it loud like the Bassani. Did you also have the Y-split redesigned?
Josh Aka Spectra SVT 02 Dark Highland Green F-150 XLT Mods: Gunrack and cowboy boots
Posts: 3,248 |
Bassani (resonator tips out) gets PEAK gain of 7HP, so does Borla. But thats not whole story. If you look at the key 4K-7K RPM powerband, the Bassani averages 6.5HP over stock. The Borla is 3 over stock. However, the Borla has a bit more low end tourque 7.5 lb/ft vs 6 lb/ft 2.5K - 4K RPM. Probably becuase it has a bit more backpressure.
Bassani is louder though, very deep note (nothing ricy about this sound) and it does drone on the highway. I ultimately put in a 4" straight through resonator & the drone was eliminated, its a bit quieter, & it sounds great (to me anyway). But that makes the total cost $600 for both parts. Thats alot for a 7HP gain. But the sound, looks, & first rate stainless construction are worth something too. Still, a Y-pipe is a better bang for buck mod.
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 945 |
I got the Bassani. It is loud.
Sounds like a V8 when idling. Defintely rip out the resonators..sounds so much better. I had them in for 5 minutes and took 'em out.
joshua_drew@hotmail.com AIM "nerdsalot2" ************************* 1998.5 Black Contour SVT 1998 ZJ Limited 4.0L AWD
