Posts: 3,237 |
Originally posted by SoupMan: Aussi, stupid question from me.
Will it fit the Contour 98 GL? Also, is it an easy install for somebody that never did this mod before? Yes and Yes. This would have to be the easy suspension mod to do.
Posts: 265 |
Also, if anyone in the Atlanta area is interested in this mod, but maybe doesn't have the tools or a place to do it, the BTR shop is always open. Due to some pending uhh, legal matters(j/k), all work is performed in exchange for beer and pizza.  dan
Posts: 3,237 |
3 more people and we are ready to Rock and (not) ROLL!
Posts: 567 |
Add my name, please. John Herrick
CURRENT RIDE: 95 GL FORMER RIDE: 99 SVT ( www.mysvt.com) "You only live once, but if you lived my life, once would be enough." -Frank Sinatra
Posts: 88 |
Aussie,
Thanks for the previous answers.
Another question. The bushings that are provided, are they high quality bushings (my understand after reading was that yes)? If so, what brand name?
Since I'm a newbie, is it strongly suggested to get two bars, front and rear?
I'll let you know by the end of the week if I'm in the group buy.
SoupMan
Contour 1998 GL Sport, Zetec 2.0L Nice cover lights, Painted calipers/Drums, Painted wipers arms, 24mm AAM Rear Swaybar ... Eh, nothing fancy yet!!
Posts: 265 |
I'm not Aussie, but I can answer those questions for you.
The bushings are Prothane as stated by Aussie earlier in this thread.
Very few people mess with the front sway bars on these cars, as there's not much reason to do so except for an all out road-racing setup. Just do the rear and you will be set.
Fwiw, I'm pretty sure SVT's have a 19mm front sway bar, as opposed to the 20mm unit found in the rest of the line. This was done for a more neutral balance. I suppose a non-svt owner could put one in if they wanted to, but I've never heard of anyone doing that. I seem to recall that the front bar is a real bear to remove.
hth, dan
Posts: 3,237 |
Latest List....29 people where almost there!
Andrew Norman Josh Hanson Patrick McQuillen Greg ? DemonSVT@kc.rr.com Andy Million Alex Strouthopoulos Ryan ? (riddik104@aol.com) Ryan Kellog Matt Marshall Mark Odette Josh B Tanner Lee Ehinger Ryan Turner Seth Adams ??? (WATTSPXR@aol.com) Dan Beggs Brian Whitton Mike ? (lawnmower70@hotmail.com) Uridian Mannon Mark Wilson Steve Chang Nikolas Malechikos Mike Ballard Lon Howell Brian Jackson Chris Root Justin C. Boeckler Shaun Guanco John Herrick
Posts: 3,248 |
Aussie, My only concern is the fact that the SCA bars invariably clunk without welding in some endlink support braces. Any idea as to why one bar would and one bar wouldnt clunk?? Ive got an SCA bar still in my garage and I'm still thinking about installing it but Im not too thrilled with the idea of paying another $40 for the endlinks + the cost of welding (which will probably equal the cost of your bar). So I guess my concern is that the clunk may show up over time - what do you think? Otherwise, Id probably get on board - looks like a very nice piece. Well done!
Will you be selling these down the road? Do you also include the poly endlink bushings as well as the poly sway bar bushings?
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 620 |
I'll be #30. I've just emailed you. Thanks for doing this!
Black '98.0 GL V6/MTX, tints, SVT airbox (sans fender boot), stock muffler replaced with spiral racing muffler, A6 side markers, Cougar 16" polished wheels w/ bald 205/50/16 Yoko A520's, Mobil 1 5W30, Castrol SATF/Ford FM tranny cocktail, 9005 high-beam bulbs all around, re-aimed stock foglights
Posts: 217 |
just added my name to the list
