I've got 2 questions for the group, hopefully someone can help cuz the mechs have just about said they won't touch my car anymore. Driving around town one day, I noticed the temp shooting up quite rapidly (got up to near the 'L'). I pulled over and noticed the cooling fans were not working. Call me dumb, but i suppose the fans should have kicked on long before the temp reached that high. Took it in to get serviced and they can't find anything "wrong" with it, yet it keeps blowing a 60 Amp fuse under the hood. I've replaced the temperature sending unit and still the same. If you disconnect the temp sending unit(not the sensor), the AC stops working but at least the fans do kick on but never turn on, logicaly i supposed since they have no signal from the sending unit. Otherwise, the fans won't come on at all. Any suggestions?
Question #2
Are there any "pre-drilled" holes on the firewall that would allow me to run some wires for my amp into the pasenger cabin, preferably on the driver side? Thanks
-ROD
