Page 2 of 3 1 2 3
bret Offline OP
yeah, i didn't plan on running with the a/c... no one runs the 1/4 mile or on a track with the a/c on... so i wouldn't waste my time. i am however aware of the cost to get my car on the dyno. but in the long run, the inital cost is not as much as additional runs... so why not get as many pulls as i can with different mods on them?
if you can get me a picture of the "screw" i need to adjust to "pin" open the secondaries that would be great.
also any mods that are not complete (i.e. ready to bolt on) could you please get them to me ASAP so i can go over what needs to be done to finish them, so i don't waste time trying to figure them out on the dyno...
thnx.
so far here i what i have
1) 65mm tb - rara
2) 80mm maf - tcobra
3) pin open secondaries - sandman33
4) th fix - TheContourGuy (not sure if i will do this one)
i am offically a troll... so take my information and advice with a grain of salt.
08/15/2001 - 11/05/2001 : 1999 Ford Contour SVT : 170fwhp - 147.9 fwtq
07/17/2001 - __/__/____ : 2001 Roush Mustang GT Stage 1
11/05/2001 - __/__/____ : 2001 Ford F-150 SVT Lightning
)[/b]
I can't get pics in time, I don't have a digital camera. frown
See this thread for a description of the set bolt for the secondaries. It is not "pinning" them open all the way, just a tiny amount (about 7 - 15 degrees). I think this provides just enough airflow to take some advantage of the second intake valve before the secondaries open on their own without causing a drop in low end torque. This extra airflow probably also provides a little tumble inside the combustion chamber, and that should enhance power/fuel economy also. You may or may not see a difference on the dyno. I noticed a bigger difference a week after the mod, when the computer had had enough time to learn the new engine behavior.
95 Contour SE ATX V6
"Cracked" Secondaries
DMD Installed
SVT Brakes
Administrator
Administrator
when are you going bret?
It's all about balance.
bcphillips@peoplepc.com
bret Offline OP
looks like friday after work... i will let you know once i have a set appointment.
well, i am not doing 25 runs... smile so maybe an in and an out would work... but i doubt i will have time to try different sized holes (this time) maybe one variation. any suggestions?
Try some NOS!!!!! Guarranteed to run just once though if you pull it off on the 25th run! Eek!
Ba
Ford Contour SE
Silver w/Black Writing
...Heavily Modified Engine...
SVT Parts added for Performance
and those downright good looks!
1
1
EGR Restrictor Plate!
UBRF.org , Western New York's Premiere Automotive Forum.
Yeah, I got some bolt-ons.
Car Pics
Video of Brullen cat-back on a \'95 SE
How-to: Short Shifter for Pre-98 MTX
"heres the deal $2 grand buy in winner gets the cash and the girl and the respect. We'll race from 0 to Inf. until I win." - someone on the internet
Yeah, second motion for the EGR restrictor plate....
Marco Tatta
98.5 SE MTX, Duratec
EGR block, fog light
fix, custom shift boot, monsterflow intake, Ecotek valve
Quasi dual cardoctor exhaust.
Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
F
F
I never meant to imply that people ran the 1/4 mile with the AC on ... anyone with common sense knows better. But since when does going to the dyno have anything to do with the 1/4 mile ... the two are completely sperate beasts! Sure, you can tune your car with the dyno to run better in the 1/4 mile, but the two are still seperate. You go to the dyno to see how much HP/TQ your car has ... you go to the track to see if you can get that HP/TQ to the ground to the best of your ability. What I was getting at was finding out how much the AC saps from the engine. Out of pure curiosity of course wink
Also, about the AC cutting out at WOT ... this isn't an instant act, it takes time for the car to figure these things out. I would have to say that the AC robs the engine of at least 15hp, maybe more like 20-25hp, but nobody will know unless you try this.
Best Regards,
Trevor Cole
New Edge Cougar Forums
EGR plate is a non-issue at WOT
\'94 Cobra #4963/5009, black on black, not quite stock
Formerly owned a black '00 SVT, #1972
Join the SVTOA!
RIP - Ray "Old Fart Emeritus" McNairy
Well, how much is it to dyno up there??? Kansas the dyno is 46 bucks for 2 baseline runs!!!!!
Any one beat that without discounts???
Merlin
281hp 324tq
Timing 14' FP 36,24lbs,190lph,75Maf,65tb,cobra upper&lower,B303, GT-40 Crate with X al heads, Mac shorties, Off Road H,2chamber Flow's dumped, Tokico 5wys, Hotichkis Ctrl Arms, Alum Drive shaft, 3.73, Sub Frame,Steeda Tri-Ax, 94 Seats Drivers side powered.
Page 2 of 3 1 2 3
