Blorton Offline OP
Subject line says it all - saw a conversion somewhere but can't seem to locate it now.
Thanks,
dan
Master P
Master P
lb/min x 13.2 = cfm
Blorton Offline OP
Thanks p-dog. You da man!
dan
Administrator
Administrator
n/m
It's all about balance.
bcphillips@peoplepc.com
Don't forget that lbs per cubic foot depends on temperature.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
Blorton Offline OP
Ok Paul, so how would I correct to "standard" flow if I have readings from different temps?
dan
Administrator
Administrator
don't worry Dan, the conversion factor perry gave you will give you scfm (standard cfm) because the temp is taken into account when measuring the mass flow rate (the lb/min)
Blorton Offline OP
Thanks Rara - but I'm trying to correlate some readings I'm getting now with some I got a few months back with lower temps. There's a bif difference between the readings.
dan
Administrator
Administrator
dan,
email me
bphill24@ford.com
