I wish I had the 5K this guy wants . . .
Now the info :
Motor:
B23FT
Volvo 240 intercooler
405 BCP K-Jet Head
O-ringed block
B230FT oil pump
"K" cam
MVP cam gear
Ford 60/63 T3 turbo
Late model Intake and Exhaust manifold conversions
Custom built 3 inch exhaust ( flanged muffler for track removal ) ( no cat )
K&N filter w/ air box mod
Terminal 11 trick at 12psi
HKS SSQ BOV & Forge BPV
G valve
Extra breather tank ( coming from older 240 valve cover )
Spark plug boot covers by Heatshield Products
Late model in-tank fuel pump
Injector lines wrapped in Cool It Thermo Tec Thermo-Shield
MSD Blaster 2 coil
Nology plug wires
Electric fan
3-core Nissen radiator
Adjustable voltage regulator
Philip Bradley style battery wiring upgrade
Battery/Motor cut-off switch ( for track )
Poly alternator and power steering bushings
12k or so on motor, oil changed every 2k w/ redline only
Chassis:
Mildly gutted/lightened to 2710lbs. w/ full fluids
GT braces ( top, bottom, and reinforcement plate )
Cherry Turbo strut brace
Oogah horn
Suspension:
KYB struts
Bilsteins shocks
IPD sways ( 25mm front and 23mm rear )
EuroSport Tuning Springs
MVP adjustable pan hard bar
Poly torque rod bushings
Tranny:
Rebuilt Borg-Warner T5 (mustang GT Transmission) w/ PRO 5.0 shift kit
Lightened flywheel
Carbon / Organic clutch
Rear Axle:
1030 axle housing
Detroit True Trac LSD
4.10 R&P
Brakes:
Cross drilled Brembo rotors
Rebuilt and color matched calipers
PBR Metal Master brake pads
Braided stainless brake lines
ATE Super Blue brake fluid
Other:
No A/C ( factory noA/C car )
Autometer Phantom Seriers gauges
IPD white gauge faces
Momo Steering wheel
17x7 Volan wheels w/ 215x45x17 Yokahoma AVS tires
