Page 1 of 5 1 2 3 4 5
My shifter suddenly has excessive play front to back, probably 1" or more while in neutral. The torx bolts are tight. The bottom cable slides freely in and out of the sleeve. As of now all gears are available. From what I've read there is probably something awry in the shifter tower, does that seem a plausible explanation? Will the new Focus tower solve the problem?
What has become of the issue involving the smaller round cable ends and larger square cable ends? SVT ST PETE linky Bill Jenkins linky From Pete's post it seems that the square/rectangular ends are from 98 SVT's and Foci but are now discontinued? Me =
Anyone have a parts list/numbers together for doing this?
9
I have a lot of parts from the Contour shifter tower if you can diagnose which parts you need. I had similar problems with mine after installing the Steeda short shifter and ended up buying an entire new unit to replace that small white piece of plastic ont he side of the tower.
"Redline is just a suggestion... Sometimes isa necessary to missa use the car..." -Enzo Ferrari
I had no problems with the Focus clamps on my 98.5 CSVT....
Ryan Trollin!
U
U
Maybe this can help you out a little. It will at least give you something else to go on, for now.
As for the Focus Shift tower issue, I would look to see if you have the square/rectangle ends before you started ordering parts.
Phillip Jackson `98 Mystique LS 262K+ and counting... ATX rebuilt @ 151K "This storm has broken me, my only friend!" RIP Dime
LOL I found that yesterday too; and even after sleeping on it I STILL have no clue what I'm looking at! I'm guessing that is the internals of the "shift tower?" Does the Focus tower come with new bushings to replace the one's that guy JB welded? He said the bushings were only available with the replacement Contour tower so surely they're included with the Focus. What is the cost to do the Focus tower upgrade?
I'm still driving the car; 1st, 3rd, and 5th aren't too bad but 2nd and 4th are iffy. Probably has something to do with the fact that for 1, 3, and 5 the cable is pulling whereas on 2, and 4 it is pushing. Hope to pull it apart tonight to see which cables are in there.
The slack appears to be caused by a faulty bushing outside the tower.
How do you get down there to remove that bushing from the cable?
It looks like all I might need is one of the ends for the cable but I can't verify until I get in there. Nor can I tell if I have the older squarish style cables or if I have the newer round ones.
no suggestions on how to get to the shifter cables? pretty please?
Easiest way I could do it:
(Do it when engine is cold, it can be a tight fit and you don't want to get burned)
1. Jack up driver side (use jackstands)
2. Remove wheel
3. Remove splash shield
4. Remove wheel well liners
5. Open hood to allow for some light
It's a lot of work, but I had to mess with the cable ends a lot, so I needed the room.
The end result of the Focus Shift Tower situation:
- Check your cable ends befor buying the Focus Shift Tower & cable ends
- The "older" 98/98.5 cables & ends are compeltely different than the later 99/00 "revised" () cables & ends
- The "older" 98/98.5 cable ends are almsot identical to the Focus cable ends
See my post for pics
I'm still searching for 98/98.5 square cable ends.
Bill looked everywhere he could for them and found nothing.
You'll know which cables & ends you have once you can clearly see them. The "revised" ones are much flatter, whereas the 98/98.5 cable ends are much fatter.
HTH
Capitol CEG Classifieds Make an offer! 2005 GTO IBM - 337hp/336tq
U
U
Thanks SVT ST PETE!
No problem.
One additional thing of importance:
If you take off the cable end(s), do not assume you are done.
Get into the car and try shifting through each gear. You may need to adjust the position of the cable ends to achieve optimal shift points.
Once you have determined shifting is all good, then button it all back up.
