Page 3 of 3 1 2 3
I would think the heat is going to be coming from the heads and valve covers, which will move on up through the LIM to the UIM by touch, and also by the valve covers extreme heat sitting directly UNDER the edges of the UIM.
How to fix that problem? Bigger rad and water wetter to keep the coolant cool which will bring down those engine temps.
Although that coating sounds like it would sure look purty
Another great idea to help underhood temps is wrapping the exhaust manifolds.
I don't think theres much else you can do.
Oh, a CAI w/ heatsheild would probably help alot. IIRC, Stazi said that the vents in his hood kept his UIM so much cooler because the underhood heat was vented out, and the filter was getting cool air in, which kept the UIM cool.
Originally posted by JonnySVT:
Not too sure, but either way, the prices look fairly cheap so even if it doesn't do much performance wise, it will at least look good.
Silver 98 SVT Contour E0 #4121 Reborn with 3L 6/03 Dyno: Max Horse Power= 194.1 Max Torque= 184.8 http://www.geocities.com/speeddemons19 Also at www.cardomain.com/memberpage/561067
that's my thinking, too. i was debating getting in on the GB, but i don't think it makes much sense unless i was going to send in headers and a Y-pipe.
good suggestion!
1999 Cougar V6 MTX Borla stainless, dual exhuast ST200 struts, rear strut tower brace Roush springs, rear sway bar, bodykit Steeda Tri/X, Powerslot rotors, Falken Ziex 512 Awaiting install: GMK CAI
Page 3 of 3 1 2 3
