Page 2 of 3 1 2 3
I see what you're saying and I didn't think about the underside of the UIM being coated, which is obviously most important. Isn't the ceramic coating supposed to act more as a heat trapper (as used on headers to prevent heat radiating from them) instead of a heat blocker(as in not letting heat into the UIM)? Not too sure, but either way, the prices look fairly cheap so even if it doesn't do much performance wise, it will at least look good.
99 SVTC, T-Red, #652/2760-12.8.1998 Mother#@%@!* did I sound abstract? I hope it sounded more confusin than that!
Originally posted by JonnySVT:
Isn't the ceramic coating supposed to act more as a heat trapper instead of a heat blocker
That'd suck if this is true! I thought it could be used as both...anyone?
Derek Scion xB 5-spd Previous: 2000 Silver Frost SVT Please share the road with cyclists.
Ehh, don't get worked up about it, it's purely an assumption.
You guys need to go visit Jet Hots website. They have a great propduct out there. I have my headers and y pipe coated by them. They coat the outside and the inside.
06 GMC Sierra 2500HD Dmax/ally 06 Pontiac G6 GT 05 CRF250R FOR SALE 06 KX65 with riding gear $2700 obo
Whoa! The inside too?! I think that would be a bad thing...wouldn't that decrease the ID?? As in someone getting their UIM EH'd then Jet Coated = not good?
The coating isn't that thick. I don't know off hand how thick it is but it should state it on the website. Otherwise email them or call them. They are very nice people and will answer all your questions. Pleasure to do business with.
The coating is only about .003-.004? thick and will reflect the surface texture.
2005 Ford F150 SuperCab FX4 1964 Chevrolet Impala SS 1998 CSVT: 354HP/328TQ @ 10 psi, now gone
nairnada difference in air flow most likely.
2004 Evolution VIII cams-exhaust-tune 315whp 12.7@109
On UIM's and LIM's they only do the outside...no inside coating like on headers and exhaust. Also remember 30% reduction in temps that's got to help a little and as you all know every little bit helps on these cars And for only $77 why not it certainly can't hurt.
Call Chris...his number is in the GB, he is very knowlegable and will answer all your questions.
Scott
Scott 2000 Contour SVT #1464 Mustang Dyno: 171.6hp/145.3lb Dynojet Dyno: 171.1hp/148.9lb 1989 20th Anniversary Turbo T/A "Indy 500 Pace Car" #1376 of 1550 All Original, 46k with a few mods 2002 F150 SuperCrew
The ceramic coating is a heat barrier.
The inside coating on a header keeps the header from receiving the full temperature of the exhaust gases, also keeps velocity up.
The "insulating" effect of the coating also increases the lifespan of the headers by reducing the peak temperatures they "see".
The coating on the outside of the headers keeps the engine bay cooler.
Page 2 of 3 1 2 3
