Posts: 23 |
I just installed KKM + Miks heat shield in a '99 SVT. Performance is improved and there's a little more rumble, in general, but there's also a high-pitched whine on acceleration.
**Is this normal?**
If it is normal, the pros outweigh the con (i.e., the whine). If it's not normal, any idea what I did wrong?
Steve 1999 Tropic Green SVT #2434 of 2760 KKM w/ heat shield SHO Y-pipe Borla cat-back (rumble, rumble) Unexplained RPM hang
Posts: 1,355 |
Do you have the "whine" at idle too? Sounds like you have moosing. You have to do the TH fix to stop it. Directions are in the FAQ.
Simon W. Las Vegas. 96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!) 1999 SVT Engine SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT "it's only nuts and bolts" - Terry Haines "Drive it like you stole it" - Me!
Posts: 3,421 |
that my friend would be the mooooossseing,, that can be takeing care of by doing the TH-fix,,
Posts: 3,421 |
hahaha same time there Simon96SE
Posts: 23 |
No whine at idle.
If I put the petal to the floor I hear a high-pitched whine as I accelerate.
If I just blip the throttle I hear a chirp.
If this is a moose, it's a castrated moose!
Posts: 1,355 |
Originally posted by I-Dom-In-8: hahaha same time there Simon96SE Great minds think alike...and at the same time it seems...lol.
Posts: 1,682 |
if it is not TOO loud (like you can't hear it with the radio on low) then it is just the air being sucked into the filter... mine does that a little... kind of like a whisting noise.. not really a whine...
Posts: 1,355 |
The noise from air being sucked in is TOTALY different from the moosing noise. If you getting the noise when you accelerate then that might be what your talking about, just air being sucked in, but if you have this noise at idle or just cruising around, then its moosing. I have the moosing right now as I took out the TH fix. The moosing goes away when I accelerate.
Posts: 4,899 |
The whine is normal. I have the KKM & a homemade heat shield and the sound is a bit whiney. The heatshield I made changed the sound a bit.
Posts: 150 |
That whiney sound I noticed for a while. I just tell people "That's the turbo." LOL
When life throws you lemons.....Pucker up.
