Posts: 620 |
Originally posted by Blorton: But....since you have a Zetec, I'd tell you to get one of those cheap headers instead. You'll prolly get comparable gains and be able to stick with cheap gas. Could you tell me more about these "cheap headers"?
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth " mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip involuntary mods: compression increased after head gasket failure
Master P
Master P
Posts: 5,455 |
Originally posted by Paul Kienitz: Could you tell me more about these "cheap headers"? Nevermind Blorton, he's being a smartass. He's talking about the ones at BAT I'm sure, and he knows they won't fit, but he wants me to buy them anyways.
Posts: 620 |
I always did have a hard time believing that a header, by itself, could make any substantial difference...
I've been warned that certain exhaust mods, like gutting the cat, can lose power because it scares the computer into playing it safe and assuming something is not working right. Hopefully it would show a CEL if this happens, so you'd know.
Posts: 2,631 |
Well, ya never know till you do it. I gained 11hp and 6tq from off road Y-pipe from sho shop. Check my dyno's in my sig with the mods. Originally posted by Paul Kienitz: I always did have a hard time believing that a header, by itself, could make any substantial difference...
Merlin
281hp 324tq Timing 14' FP 36,24lbs,190lph,75Maf,65tb,cobra upper&lower,B303, GT-40 Crate with X al heads, Mac shorties, Off Road H,2chamber Flow's dumped, Tokico 5wys, Hotichkis Ctrl Arms, Alum Drive shaft, 3.73, Sub Frame,Steeda Tri-Ax, 94 Seats Drivers side powered.
Master P
Master P
Posts: 5,455 |
I've been warned that certain exhaust mods, like gutting the cat, can lose power because it scares the computer into playing it safe and assuming something is not working right. Hopefully it would show a CEL if this happens, so you'd know. Check these dynos on a ZX2. UDP was the only mod, but you can also see the gains of a header above the already installed mods. http://www.zx2racing.com/stockdyno.htm Not "substantial" but about what would be gained with a superchip. About a 10% gain. Unfortunately, the company that made that header isn't around (at least I can't find their website).
Posts: 3,584 |
40-50 hp increase with the S/C could be the "take home" hp, not the total, thats something to think about too. As far as the chips go I was told that maybe our cars are calibrated well enough and thats why a $300.00 chip may only give you like 4-6 hp, is it worth it?
Roger R
Roger R SVT/SHO Society SE MI rep 2000 CSVT #1253 of 2150 silver frost/midnight blue 2-8" dark blue racing stripes Mequiars...simply the best! "...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4" USMondeo@aol.com
Posts: 39 |
I agree that the "off the shelf" chips like Superchip and Hypertech will typically only give you a 4-5hp gain at the wheels. These companies simply use the computer code from your EEC to make a "general" program. The best chips to get are programmable ones like Autologic. They can hold 4 separate programs. They can be custom made during dyno-tuning sessions. On-the-spot changes can be quickly made. An experienced shop usually has a Dyno-Jet, wide-band O2 sensor, and Autologic software. I personally recommend Johnson Motorsports www.jmschip.com After doing some mods to my '95 5.0 Mustang, I encountered some drivablity problems. After a couple of dyno pulls with the wide-band O2 sensor hooked up, we discovered that my new Pro-M mass air meter was leaning out my A/F ratio. A few more pulls and a couple of gradual changes to the total timing and A/F tables in the chip, and we found the "sweet spot" my car needed. When all was said and done, I gained 13rwhp and 10ftlbs torque. Because of my underdrive pullies, we set the idle speed at 900rpm for a full charge at idle. When I got the Vortech installed, we dyno-tuned it with same chip. The drivablity issues are gone. It now has docile street manners with an explosive rush of full-on power. I was pleased with the results of the JMS chip and Chris Johnson's tuning knowledge. I plan to get another Autologic chip dyno-tuned for my '98 Contour SVT. I will post the results when it's done.
Wife's car: '98 Contour SVT, black, drop-in K&N, no reasonator w/stock mufflers, Optima red top gel cell battery #0703 of #6535 My car: '95 Mustang GT, teal/gray cloth, w/Saleen body kit, 13" Baer brakes, GT-40 intake, Edelbrock heads, stock cam w/1.7 RR, 75mm Pro-M, 36lb injectors, custom JMS chip, MAC longtube headers, Vortech S-Trim (6-7psi), and way too many more mods to list... 382rwhp 379ftlbs torque with a very mild tune from JMS Visit www.sn95.com
Posts: 1,682 |
any aftermarket chip should be dyno tunable. i know for a fact superchips is. ask gschomi.
