Page 2 of 5 1 2 3 4 5
#99088 06/20/01 11:36 AM
The main reason I did the TH Fix was to kill the Moosing. My 99 SVT was doing it constantly. I will try removing it today to see if the moosing is a winter problem only.
I also think that shifting is smoother and there is enhanced "Engine Braking" when the plug (TH Fix) is in place.
99 SVT Black/Tan #1090/2760
82K Miles.......B&M Edge Shifter
Mobil1 5-30.....Side Markers
Ford Synth MTX # XT-M5-QS
Locking Lugs....Cup Holders
Black Sail Panels...TH Fix
Aluminum Gas Filler Door
BS Potenza S-03's
KVR Cross Drilled Rotors + Pads
Dual Mode Damper - soon
Clarion head unit
Pioneer 2-ways
#99089 06/20/01 01:28 PM
I don't really have a choice....I NEED the THF. My car will randomly rev at 4000, yes 4000RPM at idle without the THF. Maybe I should have Ford take a look at it before my warranty is up in 4K miles.
1998 SVT Contour E1, Black
2001 Honda SuperHawk VTR1000F
"I bent my Wookie"
www.mamisano.com
#99090 06/20/01 02:01 PM
Originally posted by tdavidk:
Did your computer have time to learn [b]without the THF? Or was it still running with the "idea" that it was still installed?[/b]
I didn't say I threw away the cap. I'm going to give it a couple days and if the hang gets annoying...well.
If it's true that we are here to help others, then what exactly are the others here for?
#99091 06/20/01 02:44 PM
Cardoc Offline OP
Well... let's see here.. Moosing has a fix.. But it involves changing the IAC valve and hoses.. You should by all means take it to the dealership and get it fixed before your warranty runs out. Mine hasn't moosed yet..(57k) But I keep the throttle body cleaned.. As far as the cap is concerned.. I'm keeping mine.. But not to reinstall.. Just to have around. Performance has picked up a great bit without the cap installed.. Driveability has actually been better without then with it in.. I'll take the revs..
Dom cool
#99092 06/20/01 03:29 PM
Dom cool
I have the updated IAC valve in my '99 SE MTX, still had the moose. TH fix dynoed a little less in one of Ray's dyno runs... The few that it costs is worth it IMHO... plus if you bump up the size of the TB via a Mustang unit, that little IAC passage isn't so important. I'll try a few runs with my "special" set up tonight to see if it makes any difference.
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
#99093 06/20/01 04:29 PM
F
F
You've got to find the right size to drill the cap. My idle is a perfect 750. Rock steady. I've driven it with and without the cap recently with no difference in performance other than the irritating throttle hang.
Throttle hang may have been worse on my car. I didn't really bother me unless I was in traffic. It wasn't a problem during hard driving.
95 Contour mtx V6
69 Chevy C/10 pickup 307ci
02 Honda Accord
TH Fix/ Tru Rev Induction/ Leda Springs/ Spax struts in front/ Magnaflow Muffler/ Dual angled 3" tips/ Resonator removed/ Pioneer 8200 deck/ E1 wheels/ BFG G-force KDW 215/50's/ '98 SE ground effects to be painted (for sale)
3rd gear synchro has issues.
#99094 06/20/01 04:52 PM
Sounds like the IAC valve sticking open. I get this happening about every 6 months. I just pull it off and give it a good clean and the problem is gone.
// Chris Root
// '99 SVT Black / Midnight blue (#2743/2760), new engine @5000Km, revised tranny @20000Km!
// B&M Edge Shifter w/ Mondeo ST200 knob, KKM pedals, K&N, Ray's TH Fix, Fog Mod
// Mobil 1 Synth 5W30, Ford "Gold" MTX fluid, 885 fogs, 50W Halogen reverse lights
// recontents: dash clock, Mystique rear dome light, front bumper braces
#99095 06/20/01 07:16 PM
Chris...Can you shoot me an email briefly explaining what I need to do to clean the IAC. I am fairly competent under the hood, so minimal explanation should be necessary.
Thats why I love this site laugh
Regards,
"I bent my Wookie"
www.mamisano.com
#99096 06/20/01 10:19 PM
I am sorry! When I asked that Q I was asking it to Dom (cardoc). I was wondering if he didn't reset the computer and give it time to learn without the THF. This may give him false results on his little test.
I took my THF (1/4") out a while back because I was having idling problems. I was getting good acceleration also after removing the THF, and the shifts as someone said remained in the power band. I liked that, but I also knew how shi+y my car was drivability wise without the THF. So I unhooked the battery put the THF back in and let the car learn with the THF in again and havn't had any problems with idle since. If I were to go to the track I would probably take it out because I did realize that with the hang my shifts were much stronger, stayed right in the middle of the power. But I did a very short one hour test of this, so I don't know if the car was just running good with the extra air it wasn't used to having. Also I had just put the SVT air box on a day or so before my little test. So I had put to many veriables into my test to get acurate results. I just wanted to make sure Dom was being scientific before he put out info. laugh
GOD BLESS AMERICA!!!
Ted
tdavidk76@hotmail.com
'95 SE • DOB-4/20/95 • every option • Champagne • Duratec • MTX.
Mods: Taylor wires • Bosch +4 • Eibach/Sachs Super Gas (half done) • rear BAT urethane bushings • SVT air box (thanx Dom!) • fogs w/parks • 885 50w fog bulbs • Ray's THF • rear dome • lighted moonroof switch(thanx again Dom!) • tranny cocktail • minor stereo mods.
Yet to install: Front Eibach/Sachs • Front BAT urethane swaybar bushings.
#99097 06/20/01 10:35 PM
Cardoc Offline OP
Hey Ted... Yes.. this was scientific and all.. lol And whatever you do the first piece of advice I can give you is to NEVER remove the battery cable.. It takes forever to re-learn itself and ends up only getting 200 miles to a tank until three months later it finally learns. I'm up to 325 miles a tank now and loving it.. If I reset the damn thing now it will set me clear back and give me no better performance. Ford has a way with programming these modules to have "Fuzzy logic" to control things in it's own way.. let's just say the computers have a personality of their own..lol and causing the computer to go "brain dead" as little as possible helps out the most. The G-Tech performance meter said it all to me... I could feel that it was stuttering and struggling under 4 grand.. But then it showed in my acceleration times.. Once out it came back up to better than original times.. (Last time I checked it was when the exhaust was first installed).. would you believe without the cap it runs .8 faster 0-60 and I also gained .2 by adding the resistor to the intake?? Hehe... It's getting quicker.. And I'm still on my 2.5 ... not on my 3.0 yet.
All in all after driving for a week without it (Which should give the computer time to adjust) It still runs the same as when I first un-installed the cap... It pulls harder in the midrange and it seems to pull just a little stronger on the top end (just a little)...
Adding the Mustang TB is something I'm going to do shortly.. As I have one sitting on my desk..lol But I still don't think that it will compensate for the TH cap.
Dom cool
