#990472 06/27/04 01:41 AM
Are DPFE sensors interchangeable? I need one for my '95 Zetec and the local salvage yard only has '96 and up vehicles. I pulled a EGR/VR from a '96 Contour and it had a smaller connector than my '95. The color code and wire gauge were different too.
Looking on EBAY there are a few new ones advertised as fitting "all ford vehicles from '95 onward"
EBAY
#990473 06/27/04 05:03 AM
Call the dealer & ask if the part numbers for the 95 & 96 are the same. Problem solved.
The DPFE is not all that expensive at the dealer anyway - expecially if you call Signature L-M. You should consider picking up one of those new.
#990474 06/27/04 07:25 AM
go to www.advanceautoparts.com and then look for one for your car.. then for the year car you gonna pull one off of and see if its the same part number....
then you will know if its the same part number...
or you could try www.autozone.com and do the same thing.
#990475 06/27/04 09:55 AM
Thanks. According to those guys the DPFE's are pretty much universal but the Solenoids aren't.
#990476 06/27/04 10:10 AM
Look for one that is made of plastic instead of metal. It should last a little longer.
"...first he's gonna s*!t, then he's gonna kill us." 1999 Contour SVT Retrojunk.com
