Page 3 of 7 1 2 3 4 5 6 7
#989349 07/16/04 05:10 AM
Originally posted by SAV-ZX2:
Originally posted by contourdude:
So a 97 gl v6 atx w/ 12 k should do like 8.5 and 16.5?
You let me know where you found an 8 year old Contour with 12,000 miles on it and I'll tell you the specs.
Guys it's the same for almost all model years. The engine and transmission choices didn't change at all with the exception of the addition of the SVT tweaked engine.
For the last time:
ATX Zetec: approx. 11 seconds to 60, 18-ish in the quarter
MTX Zetec: Give or take a tenth or two on the Duratec ATX.
ATX Duratec: 8.7-9.0 to 60, 16.8ish in the quarter.
MTX Duratec: 7.7 to 60/16 flat quarter
SVT Duratec: 6.9 to 60/see a ton of signatures for quarter miles.
Next time, search and you shall find.
More like 12 second 0-60 for the atx zetec. And high 18s.
#989350 07/16/04 06:55 AM
SAV Offline
I keep trying to tell you all that yellow doesn't make you any faster.
Troll. 1997 VW Jetta MkIII GLS 5spd All hail my appearance on CEG!
#989351 07/16/04 11:03 AM
wow, my bronco 2 is slower than atx zetecs
15 seconds to reach 60
Russell Oval Port 3L Nearly Done MTX75 w/ Homebrew Zetec FD and Torsen Complete
#989352 08/13/04 09:08 PM
I got a 1998 SE zetec atx (and yes they do come with a zetec). I got a lil exhuast work done and a intake and i run a 12.1 in an 1/8. dont know about 1/4. but i also had my big a$$ 15 in the trunk too. and 17's. so theres an idea. 12.4 just in drive.
1998 Contour SE Zetec atx, intake, custom dual exhaust, ngk iridium plugs, 8mm wires, svt body kit, 17" motegi mr7's, b&g springs http://www.cardomain.com/memberpage/366279
#989353 11/13/04 09:25 PM
E
E
I have a 79 Ford 250 with a 460 engine with only 14,500 miles. Rust free and runs good!
95 SE MTX svt exhaust intake deer killer
#989354 11/14/04 02:09 PM
9
6.9 to 60 for ths svt...the factory manual must be wrong it say 7.7 to 60....any magazine says 7.1 up to 7.6???? i've timed mine to around 7.8 w/mods and 8.1 back in the day
#989355 11/14/04 04:57 PM
Mine does sub 5.5 on street tires.
However to answer the question the gearing is not well suited to give good results on the 0-60mph test because withthe OEM redline it takes a shift to 3rd. Just raising the redline to 7250 cuts close to a second off the 0-60 times without adding any more power. (high 6's)
A non-SVT would not be any quicker with a raised redline because the power peaks much earlier and shorter. That out weighs the extra shift.
#989356 11/15/04 01:50 AM
ummm, mine has 36,000 miles on it. I got it from my grandparents and it was rarley used.
Also, my 91 Explorer 4 door mtx with the 4.0 would whoop my tour up to 30 or so, probally a v6 mtx too cause it had good low end torque and the manual helped it get a good start, but brick aero-dynamics and little horespower in 3rd gear dosn't help it after the start.
95 LX-with a mind of its own 24v DOHC SVT exhaust and K&N=all thats worth modding Go Fighting Sioux!!!
#989357 11/26/04 07:55 PM
That's a pretty good time. You would be very hard pressed to get into the mid 5 second 0-60 time without turbo/3L etc or needing a new clutch by the end of the day . I've timed my summer car at 5-5.3 sec, very low 13s consistently, and that is with a 3L straigh six stroker motor (bored .30 over), tripple webbers (biggest you can get), big cam, adjusted timing (MSD), headers, 2 1/2 inch exhaust, HD clutch, tunable cascar muffler (loud), no cat, LSD diff, T-4 tranny, and racing tires. And that is with 265 hp (consevative) at the wheels and all in a 2300 lb car. The cornering is just as fun. I've pulled over 1 G on track slicks.
#989358 11/27/04 06:27 PM
my summer car is alot faster than my svt too
should be sitting at mid 4 sec to 60 with the current turbo.
P2 91 tsi awd, not stock P3 98 CSVT, stock
Moderated by  mbb41_dup1
