Posts: 21,653 |
Originally posted by SAV-ZX2: Originally posted by contourdude: So a 97 gl v6 atx w/ 12 k should do like 8.5 and 16.5?
You let me know where you found an 8 year old Contour with 12,000 miles on it and I'll tell you the specs.
Guys it's the same for almost all model years. The engine and transmission choices didn't change at all with the exception of the addition of the SVT tweaked engine.
For the last time: ATX Zetec: approx. 11 seconds to 60, 18-ish in the quarter MTX Zetec: Give or take a tenth or two on the Duratec ATX. ATX Duratec: 8.7-9.0 to 60, 16.8ish in the quarter. MTX Duratec: 7.7 to 60/16 flat quarter SVT Duratec: 6.9 to 60/see a ton of signatures for quarter miles.
Next time, search and you shall find.
More like 12 second 0-60 for the atx zetec. And high 18s.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 3,840 |
Originally posted by Kremithefrog: More like 12 second 0-60 for the atx zetec. And high 18s.
I keep trying to tell you all that yellow doesn't make you any faster.
Troll. 1997 VW Jetta MkIII GLS 5spd
All hail my appearance on CEG!
Posts: 3,732 |
wow, my bronco 2 is slower than atx zetecs  15 seconds to reach 60
Russell
Oval Port 3L Nearly Done
Posts: 130 |
I got a 1998 SE zetec atx (and yes they do come with a zetec). I got a lil exhuast work done and a intake and i run a 12.1 in an 1/8. dont know about 1/4. but i also had my big a$$ 15 in the trunk too. and 17's. so theres an idea. 12.4 just in drive.
Posts: 2,116 |
I have a 79 Ford 250 with a 460 engine with only 14,500 miles. Rust free and runs good!
95 SE MTX
svt exhaust
intake
deer killer
Posts: 4,292 |
6.9 to 60 for ths svt...the factory manual must be wrong it say 7.7 to 60....any magazine says 7.1 up to 7.6???? i've timed mine to around 7.8 w/mods and 8.1 back in the day
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
Posts: 9,602 |
Originally posted by tour96se: 6.9 to 60 for ths svt...the factory manual must be wrong it say 7.7 to 60....any magazine says 7.1 up to 7.6???? i've timed mine to around 7.8 w/mods and 8.1 back in the day
Mine does sub 5.5 on street tires.
However to answer the question the gearing is not well suited to give good results on the 0-60mph test because withthe OEM redline it takes a shift to 3rd. Just raising the redline to 7250 cuts close to a second off the 0-60 times without adding any more power. (high 6's)
A non-SVT would not be any quicker with a raised redline because the power peaks much earlier and shorter. That out weighs the extra shift.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 503 |
ummm, mine has 36,000 miles on it. I got it from my grandparents and it was rarley used. Also, my 91 Explorer 4 door mtx with the 4.0 would whoop my tour up to 30 or so, probally a v6 mtx too cause it had good low end torque and the manual helped it get a good start, but brick aero-dynamics and little horespower in 3rd gear dosn't help it after the start.
95 LX-with a mind of its own
24v DOHC
SVT exhaust and K&N=all thats worth modding
Go Fighting Sioux!!!
Posts: 319 |
5.5 on street tires.  However to answer the question the gearing is not well suited to give good results on the 0-60mph test because withthe OEM redline it takes a shift to 3rd. Just raising the redline to 7250 cuts close to a second off the 0-60 times without adding any more power. (high 6's) A non-SVT would not be any quicker with a raised redline because the power peaks much earlier and shorter. That out weighs the extra shift.
That's a pretty good time. You would be very hard pressed to get into the mid 5 second 0-60 time without turbo/3L etc or needing a new clutch by the end of the day . I've timed my summer car at 5-5.3 sec, very low 13s consistently, and that is with a 3L straigh six stroker motor (bored .30 over), tripple webbers (biggest you can get), big cam, adjusted timing (MSD), headers, 2 1/2 inch exhaust, HD clutch, tunable cascar muffler (loud), no cat, LSD diff, T-4 tranny, and racing tires. And that is with 265 hp (consevative) at the wheels and all in a 2300 lb car. The cornering is just as fun. I've pulled over 1 G on track slicks.
Posts: 79 |
my summer car is alot faster than my svt too
should be sitting at mid 4 sec to 60 with the current turbo.
P2 91 tsi awd, not stock
P3 98 CSVT, stock
