N
nutty97 Offline OP
N
Was wondering if someone could recomend a tire size for 17x7.5 ADR Veloce. I do have it lowered with intrax springs and wheel offset is 42 i beleive. When i put the wheels on the front i can just about fit my pinky in between the rim and the strut. would a 225/35/17 work without any rubbing issues??
Bro,
I ran 17x7.5s..and the desire is always there to run a super wide tire. But the 7.5" width will already "stretch" the tire more and make it wider than a 7" rim. There was a real cool link that showed just this...
My advice...unless you got mondo HP...or are going for just a certain look...stick with 215/45/17s. More tires to choose from...no rubbing issues...and less strain on your suspension bits. Plus...a 35 series sidewall will offer about zero bump absorption...
T-red E0 SVT ATS 17x7.5 Comp Lites, 215/45/17 Falken 512s, Ausi Bar, Boxed subframe, Poli all around, Warmonger's Opt Y, Opt TB, AFE, DMD, NGK's, Bendix Ti, Alpine, Polk, Mobil-1 0W-40, Redline MTL.
I know someone is running 235/40's on 17x7.5's. It's nearly the same ratio as our stock wheels, so the speedo difference is minimal.
I've got 225/40's on my 17x7"s. No rubbing here. Those 35 series will definitly give you an awful ride.
2000 Contour SE 2.5L ATX - Toreador Red 2001 VW Golf GLS 2.0L MTX - Tornado Red Buy my possessed VCR!!
i got 225/45/17 on mine and i get rub on the back wheels
98 CSVT droped on 17x8 tsw rims w/kuhmo 225/45/17 svt badges on fenders svt ovals frnt&rear st200 badges rear lower door painted calipers,reflector,chrome oval short ram intake pioneer deh-960 mbquart seperates PG octaneR 4ch
1
I'm running 235/40 17 on a 7.5" wheel, but with 45mm offset. Your 42 will give you more room between tire and strut, but I don't know about your fenders.
I don't rub anywhere. No rolled fenders either. Hit or miss, so I'm not recommending anything.
But, 35 will be too small. A 215 will still work, but will look a little stretched. My Kuhmo's did.
Moderated by  1314_dup1
