Page 2 of 2 1 2
8
8AZ28 Offline OP
8
It appears that the Bosch marketing strategy behind the +4 plugs is somewhat misleading. Unknowledgeable buyers are led to believe that the four seprate electrodes with produce FOUR seprate sparks. Hopefully, most people know that electricity follows the path of least resistance. Of the four electrodes, the spark will jump from the most conductive ONE. The other three are only along for the ride. If anything, they probably shroud the flame and reduce burn efficiency.
Splitfire already tried this gimmick. They almost got themselves into legal litigation for false product claims. When they introduced their split electrode design, they initially claimed it "Doubled" the spark output. This bogus claim led (ignorant) buyers to believe the plugs made TWO sparks each time it fired. Splitfire quickly dropped this claim and said that the "V" at the top of the electrode "unshrouds the spark, and promotes a more complete burn of the A/F mixture". They called this "V power". I've concluded that all of these plugs are a waste of money. But wait, there's a new "Revolutionary" spark plug comming out on the market now. They are called "Iridium Power" from Denso. I think I'll sit back and let other buyers be the guinea pigs. wink
Wife's car: '98 Contour SVT, black, drop-in K&N,
no reasonator w/stock mufflers, Optima
red top gel cell battery #0703 of #6535
My car: '95 Mustang GT, teal/gray cloth,
w/Saleen body kit, 13" Baer brakes,
GT-40 intake, Edelbrock heads,
stock cam w/1.7 RR, 75mm Pro-M,
36lb injectors, custom JMS chip,
MAC longtube headers, Vortech S-Trim (6-7psi),
and way too many more mods to list...
382rwhp 379ftlbs torque with a very mild tune from JMS
Visit www.sn95.com
by the way, the +4s were made strickly for V8s and marine applications
Paul Woodward
95 SE V6 MTX
KKM, 8mm plug wires, no badges, 75HP shot of THE JUICE, B&M T-Handle Shift Knob, MOMO Aluminum Pedals, Richbrooke e-brake handle, A-Pillar with Phantom air-fuel ratio gauge, voltmeter, and oil pressure gauge, Unorthodox Racing Pulley, In dash 5" TV screen, playstation one, Apex DVD player, Digital TV tuner. Coming soon, Sho-shop y pipe and 2.5 inch single pipe exhaust
Dyslexic man sells soul to Santa... Film at 11
Heres a tip that all motorcycle tuners abide by. By correct "cheap" plugs for your application and change them often. Keeping new plugs in the car always. There is no performance "gain" with $10.00 plugs just the false security that you can leave them in for 50,000 miles and not suffer any performance loss. My .02 worth.
87 honda civic si
88 bmw m3
89 alfa milano 3L verde
98.5 ford contour svt
93 honda NSR 250sp
8AZ28
- I'm with you. You can only have one spark at one time, period. The only thing that may be useful in knowing is that sparks and arcing electricity tend to be attracted to sharp edges/corners. This is the only place where it MAY come in useful as in the +4 or ACDelco's Rapidfire plug.
I'd stick with the single, simple NGK or Bosch platinums. Much like plug wires, unless your plugs or wires are in really bad shape, I wouldn't expect much of a noticable performance increase, if any at all.
Custom Recaro Seats, B&M, Battery Relocation
http://www.svtoa-semi.com
Originally posted by Tartan1749:
8AZ28
I bought the AC Delco Rapid Fire for the Buick and have been very happy with them.
Just put the Autolite Platinum Pro in the SVT and like others have said, they work just fine.
Cheers,
TB
Tony Boner
I'm staying away from the +4's. I don't know about you guys, but the fact that they have 4 tiny electrodes worries me. It's 4 times more likely that one of those little electrodes could burn off or fall off and give you one hell of a nightmare. Also, 8AZ28 you are a smart one for pointing the misleading advertising on the +4's. Kudos to you! And to add to the fire, if you've ever seen the electrodes on the +4's they are a good bit smaller than standard plug electrodes or even those on the single platinums. Now not only are you getting one spark instead of "four" you are also getting a smaller one. What a deal! eek
Personally, I will probably be going with Autolite platinums for the SVT.
tboner,
My brother tried those Rapid Fires in his Regal (non-GN) and it gave him a rough idle. He ended up replacing them with something else and the problem went away. Just some FYI.
-Dan
1998.5 SVT "Black and Blue" #5292
See here for MOD list.
"Washing your car to make it rain does not work."
Page 2 of 2 1 2
