Posts: 64 |
The temp guage on my 1998 Merc Mystique Zetec keeps dropping down and coming back up to normal operating temp. I've had the thermostat changed, so that's not the problem. I was told that it's probably a bad sending unit. My question is, which sensor is the one to the temp guage on the dash? There's one on the top of the thermostat housing and one under it. If someone would happen to have the part number, I'd appreciate that as well. Thanks everyone!
'98 Mystique Zetec w/ auto trans
103,900 miles
Kenwood KDC-MPV7017 CD/MP3 HU
Kenwood KFC-6889ie 6x8" 3-way speakers
'96 Mystique Zetec ATX
108,000 miles
Posts: 1,085 |
Bottom one = to gauge top one = to computer Change thermostats to 180* F
2012 Lotus Evora
95 Mystique MTX - GONE 395,000 Kms
--------- Both Zetecs
'97 Contour Mtx - stock - GONE
Posts: 2,319 |
If by "dropping down" you mean all the way to cold, then check for loose electrical connection at the sender unit first.
Posts: 31 |
Had the exact same problem on mine. It's the one underneath the thermostat that's bad.
Mark, Contour GL 2,0 ATX, -98
Posts: 64 |
Hey, thanks for the info, guys.  Now does anyone have any tips for getting at that sensor. It's not in the easiest place to get to. Will everything have to come out to get to it?
103,900 miles
108,000 miles
Posts: 1,085 |
Resonater , thermostat , hose , anti freeze - under two hours from opening the hood to washing your hands.....
2012 Lotus Evora
Posts: 64 |
Aw, nuts... I just had the thermostat replaced.  If I do this myself, how much coolant (and mess) can I expect to come gushing out of there? I'd like to make this as quick and painless as possible.
103,900 miles
108,000 miles
Posts: 31 |
I wouldn't do it myselfe. It's not expencive to fix it, and they will do it right.
Posts: 1,012 |
I don't know how different is on the zetec...But I just did mine on the SVT and I only lost a minimal amount of fluid. As long as you get the new one in under 30 seconds you should be fine...Good luck.
