#987944 06/23/04 05:32 PM
I need suggestions for a good air compressor for home use. I've got a 240 volt outlet and would prefer to use it. Also, I would prefer oil-lubed (vs oil-less), smaller tank 20-60 gallon, but not too expensive. Anybody use Campbell Hausfeld? Any opinions on their compressors?
2000 SVT Black #1400 of 2150 2020 miles as of 6-25-2006
#987945 06/23/04 06:10 PM
I have a 6.5 hp Campbell Hausfeld with a 60 gallon tank. It has enough presure and flow for what I need but the piston type makes a lot of moisture and requires a good filtering/seperation system. If I was loaded I would have bought a Kaeser 5hp screw type with seperator/chiller. But that stuff gets $, screw types are real quiet too. You would probably be good with 5-7 hp piston compressor, pay close attention to the flow rate at higher pressures, relate that info to the tools and thier requirements that you will use most.
2004 Evolution VIII cams-exhaust-tune 315whp 12.7@109
#987946 06/23/04 08:50 PM
JB1 Offline
ingersol rand makes a good compressor but they are not cheap.
00 black/tan svt, #2052 of 2150, born 2/1/00 formerly known as my csvt "Nothing in the world is more dangerous than a sincere ignorance and conscientious stupidity." -Martin Luther King, Jr.
#987947 06/24/04 01:58 PM
Depends what you want to use it for. Air nailer? Spraying paint?
98 GL sport (V6 MTX) The Durable Duratec? - (DMD, Metal impeller WaterPump, Synth & Stinky in the tranny)
#987948 06/24/04 03:29 PM
Highly Medicated Member
1. 2 stage
2. Oiled
match pressure and tank size to your needs.
Semper Fi "They've got us surrounded. Poor bastards." -Chesty
