Hello,
My contour has roughly 141k miles on it. It is a 4 cylinder. Thanks for the response. I will check what I am using for spark plugs and will look into replacing them and the wires and using that greese that was mentioned above. If those do not solve my problem, then I will be forced to have the timing rechecked. Unfortunately, my car is not spitting out any codes for any of the mechanics that have looked at it. Occasionally, the check engine lite would come on and go off. When the mechanic would plug into it(the check engine lite was never on at the mechanics) it would have no codes. The lite has not come on in quite a while now. Again, thanks and I will move forward with the information you guys provided. I will let you know how everything turns out when I get this fixed.
