Hey all,
I was just wondering how difficult it is to replace the mouldings on the door at the bottom of the windows. Mine look as though there is a metal piece in the moulding and it is starting to corrode. the mouldings are starting to come away from the doors at the corners. I don't know if someone has attempted to remove them before and couldn't or if it is just wear and tear.
Thanks in advance
N
N
At the bottom of each window? That black rubber piece?
It pulls out, but be very careful! It's sort of a piece of metal I believe, surrounded by rubber and some white powdery stuff...
If you bend it, it stays bent and can be hard to get back into shape. I seriously doubt you can get new, but you can check the salvage yards, maybe something better.
Mine are rough at the window edges too...
Um go to
www.SignatureLM.com
(You know Bill Jenkins old place of work)
I have inquired about getting some and they have them listed for about $10.00 each...
Look under collision parts, glass, then belt with strip..
Easy to pop in and out.
1996 2.5LT V6 Contour ATX My Tour+help/info pics E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
Roll your windows down all the way and it's a lot easier to pop them in & out. Be careful though to not bend them too much. IIRC, I paid ~$15 for the front drivers side piece about 4 yrs ago from the dealer. Oddly, this one piece is bulging again.
Bless our servicemen & women overseas. L.Cpl Ian Malone, 1st Battalion Irish Guards, R.I.P.
Originally posted by chongo:
Um go to
www.SignatureLM.com
Just placed my order 2 are in Vegas and 2 in LA. Then off to me in Canada sometime next week.....
i have a 98 contour and the rear chrome insert over the lights is in good conditon, but seems to be coming loose at the 2 ends. is this also a quick fix and how can it be done? how is it attached too? is it just glued on so i need to do this now so i dont loose the piece all together or is it screwed on so i can wait a while?
1998.5 Ford Countour SE Sport V6 5-spd. Black/Gray with SVT 16inch wheels. approximately 89,000 miles 2004 Toyota RAV4 L Auto Silver/Grey Leather 4,000 miles
I just put new ones on mine from Ford..less than $20 per window,.
95 V6 5SPD. Shaved bumpers,antenna,trunk lock and 1/4 extensions MIDNIGHT RED.
