Posts: 6,760 |
 Originally posted by rkneeshaw: Originally posted by Shaggy: where do you have the sender tapped?
In the ass, naturally.
Ryan
Trollin!
Posts: 829 |
Sender is in the same location as the stock unit. Hence only being able to run the aftermarket and not the OEM.
SVT Parts For Sale!PM Me.
2006 M6 Cyclone Gray GTO
1995 Mazda Protege Commuter Special
93 FXDWG Dyna Wide Glide
I'm A TROLL Now!~
Posts: 9,602 |
170's normally
180's in stop and go traffic now that it's warmer.
2000 SVT #674
13.47 @ 102 - All Motor!
Cool Toe Chris
Cool Toe Chris
Posts: 1,825 |
Originally posted by RTStabler51:  Originally posted by rkneeshaw: Originally posted by Shaggy: where do you have the sender tapped?
Heh. Nice. Thanks for the location.
Chris
NJ
98.5 SVT Silver Frost
Posts: 6,760 |
You can run both, I do.... Originally posted by Rev. Po-Jay: Sender is in the same location as the stock unit. Hence only being able to run the aftermarket and not the OEM.
Ryan
Trollin!
Posts: 829 |
Nice. I am starting to doubt the gauges accuracy. It runs upwards of 230F according to the gauge. I turn the A/C off and roll down the windows then it drops to 210F or so. I need to monitor the brain to see what the temp really is. I will prolly also flush the radiator. I am already running Water Wetter.
I'm A TROLL Now!~
Posts: 435 |
Mine runns:
Hwy-190-205 Traffic around town-210 (some times more)
since the swap I am only running coolant and water, I plan on using the royal purple additive when I have time.
Posts: 829 |
I did not have the airdam on the underside of the radiator/engine on. I think that it helps to route air to the radiator more effectively. I put it back on, flushed the radiator, and fixed my T-Stat install (it seems I had the gasket on the wrong side of the thermostat, which didn't allow the t-stat to seat properly in the housing) and now she seems cooler. The OBDII scanner confirmed the tems displayed by the gauge. I have a tighter than stock mesh on the front facia that I will remove tonight as well.
I'm A TROLL Now!~
Posts: 5,810 |
Originally posted by Rev. Po-Jay: I did not have the airdam on the underside of the radiator/engine on. I think that it helps to route air to the radiator more effectively. I put it back on, flushed the radiator, and fixed my T-Stat install (it seems I had the gasket on the wrong side of the thermostat, which didn't allow the t-stat to seat properly in the housing) and now she seems cooler. The OBDII scanner confirmed the tems displayed by the gauge. I have a tighter than stock mesh on the front facia that I will remove tonight as well.
Wow! You do know that the addition of a simple air dam to a car can increase cooling efficiency around 20% or more on some cars. If GM actually spends the money on an air dam and claims 20-40% increases in cooling efficiency then you know it must be necessary.
See My Mods
Posts: 1,859 |
Usualy air dams are more for gas mileage, at least in most Gm cases. They can actualy give 1-2 mpg
'99 Silver svt
For sale
19" Axis Neo wheels
3.0 parts, pre-98 trunk,
Check classifieds
bp.powell@comcast.net
