Posts: 829 |
What temp should I run with the full 3.0L (return fuel rail)? I run upwards of 220F. I know that I am running hot, but how hot? Keep in mind that I am in PHX and it is like 115F outside with the A/C running. I have the fans coming on a bit more aggressively that stock and am also running a cooler thermostat... Should I be concerned? When does she melt down?
SVT Parts For Sale!PM Me.
2006 M6 Cyclone Gray GTO
1995 Mazda Protege Commuter Special
93 FXDWG Dyna Wide Glide
I'm A TROLL Now!~
Zippy Zetec on his last legs.
Posts: 1,262 |
nascars begin to overheat at 240...
Regards, Cole.
Relegating to troll status sometime this week.
New Whip: 1990 Lexus ES250.
Old Hotness: 1995 GL MTX Zetec *IN TRIAGE*
"I had a little friend once, but it dont move no more...  "
Posts: 5,810 |
Should run the same temps as your 2.5L. Mine always did with my 3L in AZ so I don't know why yours wouldn't.
See My Mods
Posts: 6,760 |
I'm usually right around 195ish, then if I idle for extended periods of time it gets upwards of 210-215.
Ryan
Trollin!
Posts: 829 |
Originally posted by warmonger: Should run the same temps as your 2.5L. Mine always did with my 3L in AZ so I don't know why yours wouldn't.
I have an Autometer gauge in and i am not sure how accurate it is. I no longer have the stock one connected. I guess I will hook up the OBDII and see what it is really reading... What are the normal operating temps on the 2.5L and the 3.0L?
I'm A TROLL Now!~
Posts: 6,760 |
I run an Autometer as well, electric, and my 2.5 ran the same temps as my 3.0L does...
Ryan
Trollin!
Posts: 397 |
Originally posted by Rev. Po-Jay: What temp should I run with the full 3.0L (return fuel rail)? I run upwards of 220F. I know that I am running hot, but how hot? Keep in mind that I am in PHX and it is like 115F outside with the A/C running. I have the fans coming on a bit more aggressively that stock and am also running a cooler thermostat... Should I be concerned? When does she melt down?
Uhhmmm..that can't be good...
(DemonSVT)
"Depending on ECT the PCM can pull up to 80% timing.
ECT timing pull is -10 at 200, -20 at 220, -40 at 230, -60 at 254, & -80 (i.e. default for bad sensor or maxed reading) Interpolate between the numbers Fans kick on at 216 & 224 or -18% timing & - 22% timing respectively. Stock curve has about 32 degrees of advance. SVT curve almost 40 degrees.
That's just the straight timing pull. There are many multipliers based on temp via load & rpm as well.
That's probably 10 to maybe 20 HP & TQ lost. Hard to quantify since I've never dyno'd the power loss from losing the majority of your spark advance."
T-red E0 SVT
ATS 17x7.5 Comp Lites, 215/45/17 Falken 512s, Ausi Bar, Boxed subframe, Poli all around, Warmonger's Opt Y, Opt TB, AFE, DMD, NGK's, Bendix Ti, Alpine, Polk, Mobil-1 0W-40, Redline MTL.
Cool Toe Chris
Cool Toe Chris
Posts: 1,825 |
Originally posted by RTStabler51: I run an Autometer as well, electric, and my 2.5 ran the same temps as my 3.0L does...
Not to hijack, but where do you have the sender tapped?
Chris
NJ
98.5 SVT Silver Frost
Posts: 6,760 |
t'ed in with the factory sending unit. Originally posted by Shaggy: Originally posted by RTStabler51: I run an Autometer as well, electric, and my 2.5 ran the same temps as my 3.0L does...
Ryan
Trollin!
Posts: 3,570 |
Originally posted by Shaggy: where do you have the sender tapped?
In the ass, naturally.
