Page 1 of 3 1 2 3
#986140 06/21/04 06:51 AM
What temp should I run with the full 3.0L (return fuel rail)? I run upwards of 220F. I know that I am running hot, but how hot? Keep in mind that I am in PHX and it is like 115F outside with the A/C running. I have the fans coming on a bit more aggressively that stock and am also running a cooler thermostat... Should I be concerned? When does she melt down?
SVT Parts For Sale!PM Me. 2006 M6 Cyclone Gray GTO 1995 Mazda Protege Commuter Special 93 FXDWG Dyna Wide Glide I'm A TROLL Now!~
#986141 06/21/04 06:54 AM
Zippy Zetec on his last legs.
nascars begin to overheat at 240...
Regards, Cole. Relegating to troll status sometime this week. New Whip: 1990 Lexus ES250. Old Hotness: 1995 GL MTX Zetec *IN TRIAGE* "I had a little friend once, but it dont move no more... "
#986142 06/21/04 09:23 AM
W
W
Should run the same temps as your 2.5L. Mine always did with my 3L in AZ so I don't know why yours wouldn't.
#986143 06/21/04 11:49 AM
I'm usually right around 195ish, then if I idle for extended periods of time it gets upwards of 210-215.
Ryan Trollin!
#986144 06/21/04 04:56 PM
I have an Autometer gauge in and i am not sure how accurate it is. I no longer have the stock one connected. I guess I will hook up the OBDII and see what it is really reading... What are the normal operating temps on the 2.5L and the 3.0L?
#986145 06/21/04 05:07 PM
I run an Autometer as well, electric, and my 2.5 ran the same temps as my 3.0L does...
Ryan Trollin!
#986146 06/21/04 05:15 PM
Uhhmmm..that can't be good...
(DemonSVT)
"Depending on ECT the PCM can pull up to 80% timing.
ECT timing pull is -10 at 200, -20 at 220, -40 at 230, -60 at 254, & -80 (i.e. default for bad sensor or maxed reading)
Interpolate between the numbers
Fans kick on at 216 & 224 or -18% timing & - 22% timing respectively.
Stock curve has about 32 degrees of advance.
SVT curve almost 40 degrees.
That's just the straight timing pull. There are many multipliers based on temp via load & rpm as well.
That's probably 10 to maybe 20 HP & TQ lost. Hard to quantify since I've never dyno'd the power loss from losing the majority of your spark advance."
T-red E0 SVT ATS 17x7.5 Comp Lites, 215/45/17 Falken 512s, Ausi Bar, Boxed subframe, Poli all around, Warmonger's Opt Y, Opt TB, AFE, DMD, NGK's, Bendix Ti, Alpine, Polk, Mobil-1 0W-40, Redline MTL.
#986147 06/21/04 05:33 PM
Cool Toe Chris
Cool Toe Chris
Not to hijack, but where do you have the sender tapped?
Chris NJ 98.5 SVT Silver Frost
#986148 06/21/04 05:46 PM
t'ed in with the factory sending unit.
Ryan Trollin!
#986149 06/21/04 07:10 PM
In the ass, naturally.
Page 1 of 3 1 2 3
