Should I use the diffuser screen that came stock on my SVT intake with a Proflow MAF? Its the same inside dima. as the MAF adapter so its not really restricting, except for the screen part.
I think I'm going to use it so is there any reason not to?
No
Its calibrated to operate w/out it..
T-red E0 SVT ATS 17x7.5 Comp Lites, 215/45/17 Falken 512s, Ausi Bar, Boxed subframe, Poli all around, Warmonger's Opt Y, Opt TB, AFE, DMD, NGK's, Bendix Ti, Alpine, Polk, Mobil-1 0W-40, Redline MTL.
Are you sure?
yes...when i put my intake on, i removed the stock screen on the MAF....no problmes at all.
A buddy of mine did the samething on his courgar witht the proflow MAF....its fine, from my experience.
Lupe
But will leaving it on have any negative effects?
Yes!
It is smaller in diameter then the MAF opening thus causing a flow blockage and disruption.
Besides there is no provision for it anyway between the Pro-M and a properly sized MAF adapter.
The adapter I have is smaller (inside dima.) then the MAF.
It came with my BAT filter.
So I should:
A) get new MAF adapter and filter. (Dont really want to.)
B)Chuck the screen and open up the adapter to match the MAF
C)Leave it the way it is cause the intake pipe is about the same dima. as the adapter.
"Besides there is no provision for it anyway between the Pro-M and a properly sized MAF adapter."
Which I dont have.
So you are putting a Pro-M behind the restrictive stock airbox and opening?
That would be pretty pointless to have a restriction before the "larger" MAF.
Which I dont have.
No. see edit above.
Either match the adapter to the MAF or buy one that fits...problem fixed.
99 SVTC, T-Red, #652/2760-12.8.1998 Mother#@%@!* did I sound abstract? I hope it sounded more confusin than that!
