Posts: 80 |
Its says in the FAQs that results can be hit or miss, I already have them (not installed) so should I use them or not?
98 SVT with 72,000 miles
Posts: 320 |
2006 fusion sel
1998 grand prix gtp(wife)
1993 dodge shadow es(winter beater)
Posts: 5,143 |
Ford Engines need to stop being so picky.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 7,117 |
If they're not used, trade 'em in for some Autolite APP764s and maybe a Mobil 1 oil change.
Posts: 80 |
Originally posted by scainerrt: don't do it . i had to learn the hard way!
Why what happened?
Posts: 2,676 |
Originally posted by KaptonContour: Originally posted by scainerrt: don't do it . i had to learn the hard way!
Why what happened?
Nothing happened, he is just affraid of what would have happened. I don't really know, but I never had any problems with them.
I got my car with them in, 30k miles on the plugs and they had developed a slight backfire when I downshifted, but that was at 30k miles! Everyone is so affraid of them, they are not better then autolites, but they didn't look that bad after I took them out. If you havn't used them yet, trade them in, there are better ways to spend money.
Posts: 9,602 |
Originally posted by KaptonContour: Its says in the FAQs that results can be hit or miss so should I use them or not?
Go ahead and spend your $40 and use them.
That will make it all the more pleasurable for me to laugh at you in 2 or 3 weeks when you come back here bitching about them and your newly found issues.
Bosch +2 & +4 plugs are a marketing gimmick. Nothing more. Plus on top of that they use the poor quality Bosch platinum plug as a base to start from. (i.e. exact same POS plug but with only 1 standard ground electrode)
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 3,506 |
my problem with them is not due to anythign bad, its mainly that your paying more form somehting that does the same damn thing as Autolites or Motorraft!!!
Basicly the spark is going to go to the cleanes prong (where the most metal is showing) and its not going to go to the dirtiest....so your only getting the same effective ness as a Autolite DP.
Also, a question that iv been meaning to bring up....wouldn;t having 4 prong spark plugs run the risk of casuing pining or detonation????....cause thats a lot more metal in the combustion chamber to heat up.
Lupe
edit: I ahve used them before in my privious car...in about 3 weeks and 1000 miles later, i was misfiring in 2 cyl. It was a hyndai tiburon running stock 10.1-1 compression ratio.
Since that experienced i ahve never used them...never will again...besides...too expensive for what they are.
Posts: 80 |
Originally posted by DemonSVT: Originally posted by KaptonContour: Its says in the FAQs that results can be hit or miss so should I use them or not?
Already spent the money. I ordered them so I dont think I can return them. I know it was stupid, thanks for reinforceing that fact. So what in your allmighty opinon are the plugs that I should get?
Posts: 1,246 |
