#981159 06/15/04 08:36 PM
My car is sitting at the dealership I took it in to get the front wheel bearing changed. They just called said it would be like 450 to change because I was going to need a new hub too. Now they havent even taken it appart and they are telling me this. Is this common these hubs breaking when they take out a bad bearing.....
#981160 06/16/04 02:49 PM
No, replacing the bearing should not damage the hub, and the hub should not have been damaged from driving with a bad bearing, unless you kept driving it after it was really, really bad.
#981161 06/17/04 03:32 PM
THanks......yet another reason why I hate dealing with Ford dealerships.....
#981162 06/17/04 04:27 PM
If the cost was for both sides then the price is not bad. It takes a lot of labor to just to get to the point of sending the knuckle/hub/bearing assembly to a machine shop to press out the old bearing and then press in the new bearing.
If you consider about 4 hours to remove and install, about 1 hour of machine shop time plus the cost of bearings:
4hours x $65 = $260
1hour x $80 = $80
2 bearings x $33 = $66
Total = $406 + misc nuts&bolts
I just replaced my bearings and lower control arm and can tell you that it's not easy, doable but not easy. FWIW.
#981163 06/18/04 10:28 PM
i just got my car back today from a dealer who replaced both hubs and realignment here is how my bill reads knuckle (hub)..264.87 knuckle hub 264.87 whitch is 767.34 for parts then 21.60 for supplies 3.50 disposal 87.50 for allignment and 303.50 for labor plus 33.08 tax total 891.42 they said that i tore my hub up so they canot just replace the bearing i gotr my old one back and it dont even look like the took the bearing out i think they just dindnt want to press them in and out.
blk 1998 svt contour custom paint by taylors house of color sho y pipe and hi flow converter fms 9m wires open element filter and sloted cross drilled roters
#981164 06/19/04 03:01 AM
H
H
Flat rate for contour front bearing replacement is 2 hrs.
#981165 06/21/04 10:42 PM
Raisor Motors Shop just called they changed the bearing and aligned the front end for $218.....they said Hub was fine pretty happy about that.....screw Elmhurst Ford!
#981166 06/22/04 11:57 PM
Man you got taken for a ride...WOW that is rediculus price you paid. I removed both my front hubs in about 2hrs myself in my garage and Canadian Tire pressed out and pressed in the new ones for $30.00 Canadian. That is insane and I would take the old ones to a front end shop and ask if the hubs are still good or not? or is just the bearings gone bad. If its just the bearings call Ford and report the incident. Dam STEALERSHIPS....lazy to press them out.
#981167 06/23/04 08:51 PM
yes that is what im going to do maybe i could get some kind of refund or something
