Posts: 460 |
brand new they are closer to $200 from Ford...the best i can get brand new from wholesale is around $140...but the best used i have found is $85 after tax and shipping with a 6 month warranty... I just want to find one for $30 like the rest of these lucky *******s!!!!
Nikolas
1999 Mercury Cougar V6 KKM Intake,SVT TB, SVT Upper/Lower, 19lb injectors, Diablo Chip, MSDS Headers, Custom Exhaust, B&M Short Shifter, Progress Lowering Springs, 18" Axis TC's, OMP Strut Bar, AAM 24mm Rear Sway Bar, Koni Struts
15.09 @ 91.54(corrected, pre-SVT conversion, DiabloChip, and Injectors)
Posts: 148 |
Yea. Where in the hell are they getting those for $30?
98 SVT Black w/ Midnight Blue Stock Rims Sparco Pedals Removed Resonator TH Fix Superwhite Bulbs B&M Shifter K&N Filter KVR Cross-drilled rotors (front) KVR Pads (front/back) Aeroquip Steel brake lines (front) #4248 of 6535 built 15.574 @ 88.35mph 15.814 @ 86.62mph
Posts: 945 |
Originally posted by chezterr: I just called Steeda again and they said they dont have any, and they sold their last one yesterday. Who sold it to you? the guy i spoke with wanted me to ask you that....
Nikolas Called them just now. Spoke to Kevin and Fred. There were 2 and one has my name on it. Not sure about the other one. MrPc: Steeda has em for 30bucks. I have seen them used/takeoff from $30 to $85.
joshua_drew@hotmail.com AIM "nerdsalot2" ************************* 1998.5 Black Contour SVT 1998 ZJ Limited 4.0L AWD
Posts: 460 |
yeah, i just called them and he said that he thought he had 2, but he only had one...you got the last one you b*stard!!! oh well..he said to call back often as they might get more in from doing conversions...
Nikolas
Posts: 265 |
Yes, and while you are calling Steeda, go ahead and pick up a set of 19# injectors also, if you don't have an SVT. I understand they are practically giving those away also.
Couple that with the 80mm maf calibrated for them, and you've got a nice package.
dan
Posts: 26 |
Heres a query for the more knowledgeable folks here: could any upgrade TB (65-70mm) be fitted with the brackets/cables to retain traction control on a 96? Seems like a good mod to do if price can be kept low with a used part, but I would like to keep TC if at all possible. Thanks
Posts: 460 |
I was thinking that we could just buy some 19lb injectors and a mustange MAF, but i called them and they said the outside diameter is 80mm but it is reduced inside to around 70mm or so (?)....it is prolly too big to attach to a stock rubber accordian tube and a KKM....
I just have to get my hands on a 65mm TB and i think i will be set for a while. My car is running rich over 5300 RPMS right now anyways, so the extra air the larger TB lets in will help me out. I will get a larger MAF too though, dont get me wrong, when is the question, not if....
Nikolas
Posts: 945 |
I just have to get my hands on a 65mm TB and i think i will be set for a while Nikolas Do you want to pay $85 for one? Some dude emailed me and said he had one.
Posts: 460 |
there is a place here in CA that will sell me one for $75 +shipping and tax...and there is also one on eBay i am bidding on too....i hope i win it... but to get one for $30....man, that is a steal.....
Nikolas
Posts: 3,562 |
Originally posted by SVT98.5: Do you want to pay $85 for one? Some dude emailed me and said he had one. I got a used 70mm one for less than that. The 65mm factory ones collecting dust on someones shelf should be much cheaper.
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
